I am using BLStat to send setpoints to my StellaZ's. I have created schedules, and the thermostat devices in HS3 are showing the setpoints I have sent. But the TRV's do not accept the setpoints, unless I manually wake them up.
StellaZ TRV's not taking setpoints
Originally posted by mikee123 View PostI am using BLStat to send setpoints to my StellaZ's. I have created schedules, and the thermostat devices in HS3 are showing the setpoints I have sent. But the TRV's do not accept the setpoints, unless I manually wake them up.
I have found a post from you about 2 years old about the StellaZ. I am also trying to create a event which polls the StellaZ's. Do I need to do that if I want to send a setpoint ? I also cannot find anything in events to poll a non listening device
I found the polling. I was looking for a trigger, so a wakeup of the StellaZ would trigger an event. That doesn't exist. But I found the action to poll it. But where do I go from here, to send a setpoint at the right time ? Can I use the polling to determine when to send or should it all work fine if I have the wakeup set right ? (I thought I had, but its not working, will check later tonight if that's set right)Last edited by mikee123; October 12, 2016, 09:53 AM.
Originally posted by mikee123 View PostI have set the wakeup to 6 mins, but have not set the polling. I need to set the polling too for this to work ? I am not changing the mode, like heat or energy save, I am sending setpoints in degrees to the StellaZ. But that shouldn't make a difference.
Are you using StellaZ's as well ?
Originally posted by mikee123 View PostI have found a post from you about 2 years old about the StellaZ. I am also trying to create a event which polls the StellaZ's. Do I need to do that if I want to send a setpoint ? I also cannot find anything in events to poll a non listening device
