IP Hackers
This is fairly common, sadly.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
the last weeks it was really terrible...
but i let homeseer block the ip and transfer to my iptable's in my router to hard block them after 2 try's
they try port 80 and also ssh and other ports, i can see that on my router.
i got more than 50 ip's blocked in 2 weeks now
This dutch provider is terrible for portscansPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
Originally posted by Tomgru View Postwhat is this?
I tightened my pw complexity and IP Hacking Lockout parameters in HS.
I have chosen to use MyHS for access to HS outside my LAN. I have seen no evidence of intrusion attempts in HS.Mike____________________________________________________________ __________________
