Go Back   HomeSeer Message Board > Legacy Software & Plug-ins > Legacy Plug-ins > Legacy 3rd Party Plug-ins > HSDROID (3P)
HSDROID (3P) 3rd Party Plug-in for use with Android devices
Old April 25th, 2012, 10:41 PM
rex2802 rex2802 is offline
No Light control
I am running a registered version (downloaded today) but can only control my Wayne Dalton Thermostat from the application.
My log shows requests for changes to the lights but nothing happens. The application is also not reflecting the true status of the lights.
Any thoughts?
Old April 25th, 2012, 10:46 PM
danhi danhi is offline
What type of lights are they (X10, Z-Wave, Insteon, ...)? Also, go into Homeseer->Setup->Interfaces and Click on HSDroid config and set the debug level to verbose. Then try to control a light and then post what you see in the Homeseer log.
Dan
Old April 25th, 2012, 10:48 PM
Attached is a copy from the log. It doesn't change whether I turn the light ON, Off or try to dim. I see why the lights don't respond because the values are always zero. But don't know why the values don't reflect the command.
Command sent to Dining Room Lights: L6 On Dimval: 0 Data: 0
Old April 25th, 2012, 11:03 PM
I don't see an attachment.
Dan
Old April 26th, 2012, 01:25 PM
Sorry about the "attachment" it was just a line of the log I copied and pasted at the end of my initial post.
It looks like my CMA11 may have bit the dust and that is why my lighting is not working but my Z Wave thermostat is.
I will dig into the CMA issue later tonight when I get home.
Old April 26th, 2012, 01:30 PM
OK, just let me know if you run into any problems.
Old April 27th, 2012, 08:48 AM
I ended up doing a cold boot on my HS PC and the CM11A initialized OK and all is well.
Old April 27th, 2012, 11:47 AM
Great, let me know if you run into any other problems.
Dan
