Go Back   HomeSeer Message Board > Legacy Software & Plug-ins > Legacy Plug-ins > Legacy 3rd Party Plug-ins > HSDROID (3P)
HSDROID (3P) 3rd Party Plug-in for use with Android devices
Old December 5th, 2012, 05:03 PM
Xtension Xtension is offline
Seer Plus
Current temp -1.0 with Aprilaire thermostat
Dan,
I'm running an Aprilaire 8870 thermostat and its associated HS plug-in that displays and controls all thermostat functions correctly within HomeSeer. In HSDroid, the current temperature shows "-1.0" (Brrrr!) All other fields display and update correctly including the set point temp.
Let me know if I can provide any data or logs should you try to resolve the issue.
Excellent plug-in!
HS2 on XP Pro, Insteon, X10 motion sensors, MR26A w/ ext. antenna, RF garage door link, Aprilaire 8870, IRlinc, TEMP08 for 1-wire, USB I/O-24 relay interface.
Old December 10th, 2012, 01:06 PM
danhi danhi is offline
Can you set the loggging on the plugin to verbose and then view the therm and send me the homeseer log?
Dan
Old December 10th, 2012, 01:50 PM
Seer Plus
Here ya go...
Accessed the therm in the lower section, changed setpoint to 66 deg in upper section.
12/10/2012 9:40:32 AM Web Server Web Server authorized login successful from: *.*.*.* User: steve
12/10/2012 9:40:24 AM HSDroid Cool set = 79 Heat Set = 66
12/10/2012 9:40:24 AM HSDroid Temp(1) = -1
12/10/2012 9:40:24 AM HSDroid Number of Temps = 1
12/10/2012 9:40:24 AM HSDroid Aux enabled: False
12/10/2012 9:40:24 AM HSDroid Plugin name = Aprilaire Thermostats
12/10/2012 9:40:24 AM HSDroid Number of Thermostats = 1, ThermNum = 1
12/10/2012 9:40:24 AM HSDroid cmd = Number value = 1
12/10/2012 9:40:24 AM HSDroid cmd = Plugin value = Aprilaire Thermostats
12/10/2012 9:40:24 AM HSDroid cmd = cmd value = GetThermostatDetail
12/10/2012 9:40:24 AM HSDroid link = /hsdroid2?cmd=GetThermostatDetail&Plugin=Aprilaire+Thermostat s&Number=1
12/10/2012 9:40:23 AM HSDroid Therm name: Main, address = 0
12/10/2012 9:40:23 AM HSDroid cmd = cmd value = GetThermostats
12/10/2012 9:40:23 AM HSDroid link = /hsdroid2?cmd=GetThermostats
12/10/2012 9:40:19 AM HSDroid Therm: Set Setpt to 66
12/10/2012 9:40:19 AM HSDroid Therm: Set FanMode to 0
12/10/2012 9:40:19 AM HSDroid Therm: Set Mode to 1
12/10/2012 9:40:19 AM HSDroid cmd = SetPt value = 66
12/10/2012 9:40:19 AM HSDroid cmd = FanMode value = 0
12/10/2012 9:40:19 AM HSDroid cmd = Mode value = 1
12/10/2012 9:40:19 AM HSDroid cmd = Number value = 1
12/10/2012 9:40:19 AM HSDroid cmd = Name value = Aprilaire Thermostats
12/10/2012 9:40:19 AM HSDroid cmd = cmd value = SetThermostat
12/10/2012 9:40:19 AM HSDroid link = /hsdroid2?cmd=SetThermostat&Name=Aprilaire+Thermostats&Number =1&Mode=1&FanMode=0&SetPt=66
12/10/2012 9:40:19 AM Web Server Web Server authorized login successful from: *.*.*.* User: steve
12/10/2012 9:37:45 AM Web Server Web Server authorized login successful from: *.*.*.* User: steve
12/10/2012 9:37:34 AM HSDroid Cool set = 79 Heat Set = 67
12/10/2012 9:37:34 AM HSDroid Temp(1) = -1
12/10/2012 9:37:34 AM HSDroid Number of Temps = 1
12/10/2012 9:37:34 AM HSDroid Aux enabled: False
12/10/2012 9:37:34 AM HSDroid Plugin name = Aprilaire Thermostats
12/10/2012 9:37:34 AM HSDroid Number of Thermostats = 1, ThermNum = 1
12/10/2012 9:37:34 AM HSDroid cmd = Number value = 1
12/10/2012 9:37:34 AM HSDroid cmd = Plugin value = Aprilaire Thermostats
12/10/2012 9:37:34 AM HSDroid cmd = cmd value = GetThermostatDetail
12/10/2012 9:37:34 AM HSDroid link = /hsdroid2?cmd=GetThermostatDetail&Plugin=Aprilaire+Thermostat s&Number=1
12/10/2012 9:37:33 AM HSDroid Therm name: Main, address = 0
12/10/2012 9:37:33 AM HSDroid cmd = cmd value = GetThermostats
12/10/2012 9:37:33 AM HSDroid link = /hsdroid2?cmd=GetThermostats
12/10/2012 9:37:33 AM Web Server Web Server authorized login successful from: *.*.*.* User: steve
Old December 10th, 2012, 02:59 PM
Seer Plus
Perhaps this will help. I set the Aprilaire plug-in to debug logging then accessed the thermostat in HS...
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG In ProcessCMD, Property= HOLD
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG Entering ProcessCMD, CMD=SN1 HOLD=OFF
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG In ProcessCMD, Property= F
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG Entering ProcessCMD, CMD=SN1 F=AUTO
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG In ProcessCMD, Property= HVAC
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG Entering ProcessCMD, CMD=SN1 HVAC=G-Y1-W1-Y2-W2-B+O-
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG In ProcessCMD, Property= M
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG Entering ProcessCMD, CMD=SN1 M=HEAT
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG In ProcessCMD, Property= SH
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG Entering ProcessCMD, CMD=SN1 SH=66F
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG In ProcessCMD, Property= SC
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG Entering ProcessCMD, CMD=SN1 SC=79F
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG In ProcessCMD, Property= T
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG Entering ProcessCMD, CMD=SN1 T=67F
12/10/2012 10:52:02 AM Aprilaire Thermostats DEBUG SN1 T=67FSN1 SC=79FSN1 SH=66FSN1 M=HEATSN1 HVAC=G-Y1-W1-Y2-W2-B+O-SN1 F=AUTOSN1 HOLD=OFF
12/10/2012 10:52:00 AM Aprilaire Thermostats DEBUG In Poll: Time: 12/10/2012 10:52:00 AM
12/10/2012 10:52:00 AM Aprilaire Thermostats DEBUG Polling stat number: 1
12/10/2012 10:52:00 AM Aprilaire Thermostats DEBUG Poll Thread Loop Starting: 12/10/2012 10:52:00 AM
12/10/2012 10:51:33 AM Aprilaire Thermostats DEBUG Exiting StatObj, returning stat with name: Main
12/10/2012 10:51:33 AM Aprilaire Thermostats DEBUG Entering StatObj: 1
Old December 10th, 2012, 03:53 PM
The Aprilaire plugin isn't returning a valid value to the GetTemp API. Is there some support for this plugin?
Old December 10th, 2012, 05:07 PM
Seer Plus
The free plug-in was developed by HomeSeer back when the Aprilaire 8870 was just about the only choice for a communicating thermostat.
Perhaps HST would release the source?
Old December 10th, 2012, 06:01 PM
Rupp's Avatar
Rupp Rupp is online now
Put in a help desk ticket and I'll assign it to Rich to get you this information using the blue support link above.
-Rupp
Old December 10th, 2012, 06:45 PM
Since I don't have the plugin, would be best for Xtension to open this ticket. The text should be that the plugin returns -1 to the GetTemp API.
Dan
Old January 2nd, 2013, 12:09 PM
Seer Plus
Help Desk Ticket Submitted
Between work and the holidays I finally got around to submitting a help desk ticket.
