Poll for Change of value for Pico
    In the process of having the ability to control counter and in the future to be able to have the double press I need to change the value of each Pico, this mean you may have to update the events you create, this will also give you the button name so no more value need. At the same time you will be able to control event by choice of Press or Release. See the attachment for more details.
    6
    Yes
    100.00%
    6
    No
    0.00%
    0
    This looks great, quick note there's a typo in both screenshots, you have Dinner instead of Dimmer
      This is just a typo when I create the device on my test machine Diner Pico you should read
        Vote for Pico changes
        Don,
        This would be a positive change......I have no issues modifying my Events as a result.
        Justin in Dallas
        HomeSeer S6 Pro, 95 Caseta Devices, Caseta Plug-in, Honeywell WiFi Thermostat Plug-in.....more on the way.
          hi,
          Would it be possible to give an exemple of an events with a double tap ON/off ( with the same physical button on the pico)
          thank you
          edit:
          I did set this up
          https://ibb.co/j0REdw
          https://ibb.co/jrBfJw
          If i press 1 time on the ''on'' it sets my lights on. If i press 2 time it sets my lights off.
          It is ok if I am in the same room, and I can see the lights states But if I am not in the same room and if the count is already set to 1... and I press two times on the ''on'' button, the counter will go to 1 again... ( so the light will stay on )...
          What i want to do is, whenever i press the ''on '' button one time , my lights will turn on, and when i press the ''on '' button two time , they will always go to off.
            I'm traveling for the next 2 weeks, I'll try to find time, also on May be able to integrate it in the plugin in the future
              Thank you Don
                I use those timer, counter and even, it may have other way but this work for me
