MR26A protocol
    MR26A protocol
    I have had some frustration over failing X10 RF receivers .
    I've got three TM13AU on the bench and they all suffer the same Bad power supply design.
    I've made a little RF receiver & have it working well , but would like to plug it directly into homeseer ( V1.7 ) instead of going via the Mains interface (tw523 Equiv).
    The MR26A looks like an interface I would like to mimic , but I can't find the protocol anywhere .
    Does anyone have the IO spec sheet for it ?
    :: Update
    The mr26a plugin included in 1.7 complains it will only work with v1.5.
    suppose I need to make my device appear like a cm11a .... Bother !
    Here was using the MR26A with last version of HS1 running which was 1.744. It worked fine after modification of the interface with an RG6 coaxial adapter and external antenna.
    Here is the definition of the X10 wireless protocal.
    I did a copy and paste over here for references sake.
    Format of RF envelope
    The carrier is at a nominal frequency of 300 Mhz. The envelope of the
    carrier is sketched below. Time progresses from left to right.
    |   8msec     | 4msec  | 0.4ms | 0.7ms | 0.4ms | 0.7ms    1.1 msec  |
         RF preample       + sampled '1'   +  sampled '1'  + sampled '0'
    The data format is return-to-zero. A '1' is sampled when the envelope
    goes high for 0.4msec and then returns low for 0.7msec. Thus with the
    above waveform, the sampled data (left bit below is received first):
    110.......
    Note that the RF preamble is not part of the sampled data, and that I
    make the distinction between the received envelope (sketched above)
    and the SAMPLED STREAM (the 110.. above). This sampled stream is
    converted to a DECODED STREAM and then converted to an actual
    X-10/security command using the procedure explained below.
    Data format for the RT-504 X-10 wireless remote
    I will explain the data format using an example sampled stream. The
    right most digit is received first:
    10101111 11011101 01010101 11011111 10101101 01010101 <-A1 OFF cmd
    The total length of the stream is 48 samples. Doing some inspection
    on this and other sample streams shows that there are multiple bit
    flips, even if the transmitted house code changes by only one bit. My
    hunch was that each bit of the house code is encoded as a varying
    number of samples in length. Changing a '1' to a '0' in the house
    code for example, will cause the samples to be shifted because a '0'
    has a different length than a '1'.
    Thus presumption was further enforced by counting the number of 0
    samples and the number of 1 samples. All messages inspected have
    exactly 16 '0' samples and 32 '1' samples. This implies that one
    symbol contains a '1' and a '0', and the other symbol contains just a
    '1'.
    Making the assumption that a '0' bit is sampled as a '10', and a '1'
    bit is sampled as a '1', we can rewrite the sampled sequence into a
    DECODED STREAM:
    00000100 11111011 00000110 11111001
     byte 1   byte 2   byte 3   byte 4
    Here, the first received bit is on the LEFT. Note that byte 1 and
    byte 2 are complementary, as well as byte 3 and byte 4. By sending
    the inverse of the bytes along as well, one can guarantee the same
    number of '1' and '0' bits in the decoded data, and the same number of
    '1' and '0' in the sampled stream regardless of the message. In
    addition, some simple error detection can be performed by making sure
    the complementary data is consistent.
    The house code can now be read in the stream. It is byte 3. Its
    associated complement is byte 4. Refering to the X-10 Faq (URL
    below), the bit patterns for the house codes are:
    House code  Bit pattern (units 1-8, 9-16 add 100000)
    	     A           0110
    	     B           1110
    	     C           0010
    	     D           1010
    	     E           0001
    	     F           1001
    	     G           0101
    	     H           1101
    	     I           0111
    	     J           1111
    	     K           0011
    	     L           1011
    	     M           0000
    	     N           1000
    	     O           0100
    	     P           1100
    In this instance, the house code of the command is 'A'. One thing I
    noticed is that units 1 thru 8 have a different house code than units
    9 thru 16. The house code for units 1-8 are as explained above, while
    the house code for units 9-16 have a '1' in bit 5 (where bit 0 is the
    right most bit). Thus the command A-9 OFF has the decoded stream:
    00000100 11111011 00100110 11011001
                        ^--------^--------note difference here
    We can find the unit and function code in byte 1. Naming each bit in
    byte 1 by a number, where 7 is the most significant bit (received
    first & left most) and 0 is the least:
    bit  function
           7   always 0
           6   always 0
           5   always 0                           |<--- from bit 5 of byte 3
           4   bit 1 of unit number --------------->|
           3   bit 0 of unit number ---------------->|
           2   1 for OFF command.                 xxxx <--(unit number -1)
           1   bit 2 of unit number -------------->|
           0   1 for DIM (if bit 3=1) or BRIGHT (if bit 3=0) command
    To clarify bit 0, if the command is a BRIGHT command, byte 1=0x11, if
    it is a DIM command, byte 1=0x19. The unit number is reassembled by
    ordering bits 4,3,1 from byte 1, and bit 5 from byte 3 above, add '1'
    to this, and you will have the unit number. In this case, the unit
    number's bit pattern is:0000, or unit #1. Since the OFF bit is set,
    the command represented by the sampled stream is: A-1 OFF.
    Another example:
    sampled RF stream:
    10101110 11101110 10110101 10101010 11110111 11010101
    decoded byte stream:
    00011110 11100001 00100110 11011001
    X-10 command:
    A-16 OFF
    Data format for the security transmitter
    Using the same samples-to-decoded matching ('10'->0 and '1'->1), we
    find that the decoded stream from the security transmitters
    (door/window and PIR) are in general 32 bits in length. For example:
    sampled stream, first received on right:
    10110111 01011011 01010111 11111010 11010101 01011101
    decoded stream, first received on left:
    01100000 10011111 11000101 00110101
    We consider the most significant bit to be transmitted first and on
    the left, thus the upper nibble is to the left of the lower nibble.
    Note that the upper nibble of byte 1 is the complement of byte 2, and
    the lower nibble is the same. This same relationship holds for byte 3
    and 4.
    Bytes 3 and 4 change when the 'code' button is hit on the security
    transmitter. We can consider these two bytes to encode the unit's 8
    bit ID.
    Byte 1 is the message code. This is as follows for a few units:
    Large security remote (SH624):
    (has a min/max delay slide switch below the buttons)
            ARM HOME (min)  0x70
            ARM AWAY (min)  0x60
            ARM HOME (max)  0x50
            ARM AWAY (max)  0x40
            DISARM          0x41
            SEC. LIGHT ON   0x42
            SEC. LIGHT OFF  0x43
            PANIC           0x44
            The other buttons transmit normal X10 remote codes
            for an RT-504 remote.
    Pendant (KF574):
            ARM             0x60  (this is apparently min delay mode)
            DISARM          0x61
            LIGHTS ON       0x62
            LIGHTS OFF      0x63
    Old door/window sensor (DW 534)
            NORMAL          0x21 (for when security violation is removed)
            ALERT           0x20 (for when sensor is tripped)
            Supervision Code: transmits a NORMAL
    New door/window sensor
            NORMAL          0x31
            ALERT           0x30
    The newer security transmitters append 9 extra bits that do not vary
    to the above 32 bit sequence (a total of 41 bits). These bits appear
    to always be 000000101 (left most is rx first).
    References:
    [1] X10 faq (http://www.homation.com/x10faq/x10faqd.html)
    Appendix
    The following is a listing of the decoded bytes from many units
    compiled by Paul. The unindented line is the command. The next
    (indented) line contains the decoded bytes. Note one difference with
    his convention compared to mine. In my text above, I list the decoded
    bytes in the order byte1, byte 2, byte 3, byte 4. His listing has
    them in byte 4, byte 3, byte 2, byte 1 order (from left to right). In
    other words, for X-10 commands, the house code is in the two left most
    bytes in the listing below.
    A- 00001 OFF
     00032: 11111001 00000110 11111011 00000100
    A- 00002 OFF
     00032: 11111001 00000110 11110011 00001100
    A- 00003 OFF
     00032: 11111001 00000110 11101011 00010100
    A- 00004 OFF
     00032: 11111001 00000110 11100011 00011100
    A- 00005 OFF
     00032: 11111001 00000110 11111001 00000110
    A- 00006 OFF
     00032: 11111001 00000110 11110001 00001110
    A- 00007 OFF
     00032: 11111001 00000110 11101001 00010110
    A- 00008 OFF
     00032: 11111001 00000110 11100001 00011110
    A- 00009 OFF
     00032: 11011001 00100110 11111011 00000100
    A- 00010 OFF
     00032: 11011001 00100110 11110011 00001100
    A- 00011 OFF
     00032: 11011001 00100110 11101011 00010100
    A- 00012 OFF
     00032: 11011001 00100110 11100011 00011100
    A- 00013 OFF
     00032: 11011001 00100110 11111001 00000110
    A- 00014 OFF
     00032: 11011001 00100110 11110001 00001110
    A- 00015 OFF
     00032: 11011001 00100110 11101001 00010110
    A- 00016 OFF
     00032: 11011001 00100110 11100001 00011110
    A- 00001 ON
     00032: 11111001 00000110 11111111 00000000
    A- 00002 ON
     00032: 11111001 00000110 11110111 00001000
    A- 00003 ON
     00032: 11111001 00000110 11101111 00010000
    A- 00004 ON
     00032: 11111001 00000110 11100111 00011000
    A- 00005 ON
     00032: 11111001 00000110 11111101 00000010
    A- 00006 ON
     00032: 11111001 00000110 11110101 00001010
    A- 00007 ON
     00032: 11111001 00000110 11101101 00010010
    A- 00008 ON
     00032: 11111001 00000110 11100101 00011010
    A- 00009 ON
     00032: 11011001 00100110 11111111 00000000
    A- 00010 ON
     00032: 11011001 00100110 11110111 00001000
    A- 00011 ON
     00032: 11011001 00100110 11101111 00010000
    A- 00012 ON
     00032: 11011001 00100110 11100111 00011000
    A- 00013 ON
     00032: 11011001 00100110 11111101 00000010
    A- 00014 ON
     00032: 11011001 00100110 11110101 00001010
    A- 00015 ON
     00032: 11011001 00100110 11101101 00010010
    A- 00016 ON
     00032: 11011001 00100110 11100101 00011010
    A - BRIGHT
     00032: 11011001 00100110 11101110 00010001
    A - DIM
     00032: 11011001 00100110 11100110 00011001
    A- 00001 OFF
    B- 00001 OFF
     00032: 11110001 00001110 11111011 00000100
    C- 00001 OFF
     00032: 11111101 00000010 11111011 00000100
    D- 00001 OFF
     00032: 11110101 00001010 11111011 00000100
    E- 00001 OFF
     00032: 11111110 00000001 11111011 00000100
    F- 00001 OFF
     00032: 11110110 00001001 11111011 00000100
    G- 00001 OFF
     00032: 11111010 00000101 11111011 00000100
    H- 00001 OFF
     00032: 11110010 00001101 11111011 00000100
    I- 00001 OFF
     00032: 11111000 00000111 11111011 00000100
    J- 00001 OFF
     00032: 11110000 00001111 11111011 00000100
    K- 00001 OFF
     00032: 11111100 00000011 11111011 00000100
    L- 00001 OFF
     00032: 11110100 00001011 11111011 00000100
    M- 00001 OFF
     00032: 11111111 00000000 11111011 00000100
    N- 00001 OFF
     00032: 11110111 00001000 11111011 00000100
    O- 00001 OFF
     00032: 11111011 00000100 11111011 00000100
    P- 00001 OFF
     00032: 11110011 00001100 11111011 00000100
    KF574 Security Pendant
    Unit # 00197: ARM AWAY (min)
     00032: 00110101 11000101 10011111 01100000
    Unit # 00197: Pendant DISARM
     00032: 00110101 11000101 10011110 01100001
    Unit # 00197: Pendant LIGHT ON
     00032: 00110101 11000101 10011101 01100010
    Unit # 00197: Pendant LIGHT OFF
     00032: 00110101 11000101 10011100 01100011
      (pushed code, and resampled, note unit # changes)
    Unit # 00061: ARM AWAY (min)
     00032: 11001101 00111101 10011111 01100000
    Unit # 00061: Pendant DISARM
     00032: 11001101 00111101 10011110 01100001
    Unit # 00061: Pendant LIGHT ON
     00032: 11001101 00111101 10011101 01100010
    Unit # 00061: Pendant LIGHT OFF
     00032: 11001101 00111101 10011100 01100011
    DW534 old model Door/Window Sensor -- strapped for N.O. operation
    pushed test button
    Unit # 00007: ALERT, N.O. old
     00032: 11110111 00000111 11111111 00000000
    Unit # 00007: Normal, N.O. old
     00032: 11110111 00000111 11111110 00000001
    DW534 old model Door/Window Sensor --  N.C. operation
    pushed test button
    Unit # 00122: ALERT, old
     00032: 10001010 01111010 11011111 00100000
    Unit # 00122: Normal, old
     00032: 10001010 01111010 11011110 00100001
    SP554A old model PIR sensor - set to Home/Away Mode
    Unit # 00035: PIR ALERT, old
     00032: 11010011 00100011 11001111 00110000
    Unit # 00035: PIR Normal, old
     00032: 11010011 00100011 11001110 00110001
    SP554A old model PIR sensor - set to Normal Mode
    Unit # 00035: Normal, old
     00032: 11010011 00100011 11011110 00100001
    Unit # 00035: ALERT, old
     00032: 11010011 00100011 11011111 00100000
    MS10A new model PIR sensor
    Unit # 00210: ALERT, new
     00041: 00100010 11010010 11001111 00110000 00000010 0
    Unit # 00210: Normal, new
     00041: 00100010 11010010 11001110 00110001 00000010 0
    SH624 Security/Home Automation Remote
    Unit # 00130: Remote PANIC!
     00032: 01110010 10000010 10111011 01000100
    Unit # 00130: Remote DISARM
     00032: 01110010 10000010 10111110 01000001
    Unit # 00130: Remote LIGHT OFF
     00032: 01110010 10000010 10111100 01000011
    Unit # 00130: Remote ARM HOME (min)
     00032: 01110010 10000010 10001111 01110000
    Unit # 00130: ARM AWAY (min)
     00032: 01110010 10000010 10011111 01100000
    Unit # 00130: Remote LIGHT ON
     00032: 01110010 10000010 10111101 01000010
    Unit # 00130: Remote ARM HOME (max)
     00032: 01110010 10000010 10101111 01010000
    Unit # 00130: Remote ARM AWAY (max)
     00032: 01110010 10000010 10111111 01000000
    End of RF protocol document.
    In the Homeseer 2 days went to using the WGL W800 serial interface which worked much better for me than the MR26A.
    That said you can update maybe to HS1.744 to get your MR26A going again if you want or upgrade to Homeseer 3 and run it on a Raspberry Pi in Linux using most current 3rd party X10 wireless plugin or use HS3 and connect it to the CM15A USB device which does wireless and power X10.
    Here still using CM11A's, TW523's and WGL W800's (well only one these days) plus Jeff Volp's stuff with my X10 wich is at 100% these days.
    It would be better to move this post over to under X10 sometime in the future.
    Auto mator
      Hi Pete ,
      Thanks for the info.
      I had the RF part of the project working well , but it's good to have another reference for that protocol on the forum.
      It is the mr26a protocol over the serial interface I have no info on .
      I am actually running HS1.7.44 and no updates are available for that via the normal web update system , so I'm a bit stuck even using an mr26a with hs1.7.44 .
      I've started work on emulating a cm11A because I have found some info on it's protocol.
      Barry
