Massive delay to insteon devices via hs3
    #31
    Hey Mark
    i upgraded to .368 and now there is a slight change in the delay
    if i turn off / on 3-4 devices at the same time, the first one takes around 5-6 seconds to respond and the rest respond 1 second later.
    i am on :
    [hub]
    ResponseTime=5
    GetXMLBufferInterval=1500
    is there anything worth changing?
    thanks
      #32
      Originally posted by ez1976 View Post
      Hey Mark
      i am on :
      [hub]
      ResponseTime=5
      thanks
      what does the detailed log look like? lots of retries?
      what about controlling individual devices? do they respond within 1 sec?
      Mark
      HS3 Pro 4.2.19.5
        #33
        Hey Mark
        bumping up an old thread about the linux insteon speed.
        since i moved to an all linux server, the insteon response time is still not as fast as windows.
        this is my configuration at the moment:
        [Hub]
        GetXMLBufferInterval=1800
        ResponseTime=5
        thanks
          #34
          Can you capture a plugin detailed log of a transaction that would consider slow?
          please annotate the log where you see the delay
          Mark
          HS3 Pro 4.2.19.5
            #35
            Hey Mark
            sorry for the delay in response.
            when i do a compare between homeseer on windows and linux, i can see a difference between the response speed.
            if i start 3 devices one after the other in windows they start in a 1-3 seconds delay between them.
            on linux there is a delay sometimes up to 10 seconds between device and device.
            i did the insteon.ini changes but its still annoying.
            on zwave for example the response is immediately but using the insteon hub i can see the difference. (when sending a group command they response right away of course)
            what would you like me to send you in the log?
              #36
              Ok it seems that as soon as i disabled automatic pooling it was a lot faster!!
              the first log is with automatic enabled
              and the second one is when it is closed
              turning on devices (3 at a time)
              Jul-15 16:32:57 Insteon Sending http://192.168.0.253:25105/3?02621FDECB0F1900=I=3
              Jul-15 16:32:57 Insteon Received a Direct ACK from Living Room Keypad (2F.BC.48): 2F BC 48 2C BA 5A 27 2E 00
              Jul-15 16:32:57 Insteon Sending command 02 62 1F DE CB 0F 19 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:32:57 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:57 Insteon ..Got Hub Response 02 62 2F BC 48 1F 2E 00 00 09 88 00 00 00 00 00 00 00 00 00 00 41 06
              Jul-15 16:32:57 Insteon Received STX 0x50 (Raw Insteon Rec):2F BC 48 2C BA 5A 27 2E 00
              Jul-15 16:32:57 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:57 Insteon ..My XML buffer: 02622FBC481F2E0000098800000000000000000000410602502FBC482CBA 5A272E0000000000000000000000000000000000
              Jul-15 16:32:55 Insteon Attempting to update the status for Family Room Shades (1F.DE.CB)
              Jul-15 16:32:55 Insteon Requesting Insteon status (Polling) for device Family Room Shades (1F.DE.CB)
              Jul-15 16:32:55 Insteon Timed poll for Insteon device Family Room Shades (1F.DE.CB), Last contact 7/15/2019 4:17:30 PM. Polling interval of 15 min. reached, polling...
              Jul-15 16:32:55 Insteon Sending command 02 62 2F BC 48 1F 2E 00 00 09 88 00 00 00 00 00 00 00 00 00 00 41 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:32:55 Insteon Setting status and value for device 2C.85.C1:1. Old status:0 Old Value:0, New Status:2 New Value:100
              Jul-15 16:32:55 Insteon Received a Direct ACK from Kitchen Gas Light (2C.85.C1): 2C 85 C1 2C BA 5A 2F 11 FF
              Jul-15 16:32:55 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:55 Insteon ..Got Hub Response 02 62 2C 85 C1 0F 11 FF 06
              Jul-15 16:32:55 Insteon Received STX 0x50 (Raw Insteon Rec):2C 85 C1 2C BA 5A 2F 11 FF
              Jul-15 16:32:55 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:55 Insteon ..My XML buffer: 02622C85C10F11FF0602502C85C12CBA5A2F11FF00000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:32:53 Insteon Sending http://192.168.0.253:25105/3?02622C85C10F11FF=I=3
              Jul-15 16:32:53 Insteon Sending command 02 62 2C 85 C1 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:32:53 Insteon Checking for keypadlinc button sync on device 2F.BC.48 src index 4, SrcIsSyncTarget=True...
              Jul-15 16:32:53 Insteon Setting status and value for device 2F.BC.48:4. Old status:0 Old Value:0, New Status:2 New Value:100
              Jul-15 16:32:53 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:53 Insteon Received a Direct ACK from Living Room Keypad (2F.BC.48): 2F BC 48 2C BA 5A 27 00 80
              Jul-15 16:32:53 Insteon Received STX 0x50 (Raw Insteon Rec):2F BC 48 2C BA 5A 23 00 80 Debouncing repeat.
              Jul-15 16:32:53 Insteon Received STX 0x50 (Raw Insteon Rec):2F BC 48 2C BA 5A 27 00 80
              Jul-15 16:32:53 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:53 Insteon ..My XML buffer: 02502FBC482CBA5A27008002502FBC482CBA5A2300800000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:32:49 Insteon ..Got Hub Response 02 62 2F BC 48 0F 19 01 06
              Jul-15 16:32:49 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:49 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:49 Insteon ..My XML buffer: 02622FBC480F190106000000000000000000000000000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:32:49 Insteon Sending http://192.168.0.253:25105/3?02622FBC480F1901=I=3
              Jul-15 16:32:49 Insteon Sending command 02 62 2F BC 48 0F 19 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:32:49 Insteon Did not receive a response from Living Room Keypad (2F.BC.48). Try #1 failed.
              Jul-15 16:32:46 BLLAN Info Computer - Living Room Reciever --- 1 PING failure
              Jul-15 16:32:43 Insteon ..Got Hub Response 02 62 2F BC 48 0F 19 01 06
              Jul-15 16:32:43 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:43 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:43 Insteon ..My XML buffer: 02622FBC480F190106000000000000000000000000000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:32:41 Insteon Sending http://192.168.0.253:25105/3?02622FBC480F1901=I=3
              Jul-15 16:32:41 Insteon Sending command 02 62 2F BC 48 0F 19 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:32:41 Insteon Attempting to get a KPL LED status response from Insteon device 2F.BC.48
              Jul-15 16:32:41 Insteon Sending sync command 17 to linked responder device: Living Room Keypad Button D: Living Room Keypad Button D - Table Light (2F.BC.48)
              Jul-15 16:32:41 Insteon SyncResponderDevices called for device code: 32.73.D4:1
              Jul-15 16:32:41 Insteon Setting status and value for device 32.73.D4:1. Old status:0 Old Value:0, New Status:2 New Value:100
              Jul-15 16:32:41 Insteon Received a Direct ACK from Living Room Table Light (32.73.D4): 32 73 D4 2C BA 5A 2B 11 FF
              Jul-15 16:32:41 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:41 Insteon ..Got Hub Response 02 62 32 73 D4 0F 11 FF 06
              Jul-15 16:32:41 Insteon Received STX 0x50 (Raw Insteon Rec):32 73 D4 2C BA 5A 2B 11 FF
              Jul-15 16:32:41 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:41 Insteon ..My XML buffer: 02623273D40F11FF0602503273D42CBA5A2B11FF00000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:32:39 Insteon Sending http://192.168.0.253:25105/3?02623273D40F11FF=I=3
              Jul-15 16:32:39 Insteon Sending command 02 62 32 73 D4 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:32:39 Insteon Sending sync command 17 to linked responder device: Kitchen Gas Light (2C.85.C1)
              Jul-15 16:32:39 Insteon SyncResponderDevices called for device code: 2C.79.48:1
              Jul-15 16:32:39 Insteon Setting status and value for device 2C.79.48:1. Old status:0 Old Value:0, New Status:2 New Value:100
              Jul-15 16:32:39 Insteon Received a Direct ACK from Kitchen Light (2C.79.48): 2C 79 48 2C BA 5A 2B 11 FF
              Jul-15 16:32:39 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:39 Insteon ..Got Hub Response 02 62 2C 79 48 0F 11 FF 06
              Jul-15 16:32:39 Insteon Received STX 0x50 (Raw Insteon Rec):2C 79 48 2C BA 5A 2B 11 FF
              Jul-15 16:32:39 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:39 Insteon ..My XML buffer: 02622C79480F11FF0602502C79482CBA5A2B11FF00000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:32:39 Insteon Starting Scheduled Polling...
              Jul-15 16:32:37 Insteon Sending http://192.168.0.253:25105/3?02622C79480F11FF=I=3
              Jul-15 16:32:37 Insteon Sending command 02 62 2C 79 48 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:32:37 Insteon Did not receive a response from Kitchen Light (2C.79.48). Try #4 failed.
              Jul-15 16:32:31 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:31 Insteon ..Got Hub Response 02 62 2C 79 48 0F 11 FF 06
              Jul-15 16:32:31 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:31 Insteon ..My XML buffer: 02622C79480F11FF06000000000000000000000000000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:32:31 Insteon Sending http://192.168.0.253:25105/3?02622C79480F11FF=I=3
              Jul-15 16:32:31 Insteon Sending command 02 62 2C 79 48 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:32:31 Insteon Did not receive a response from Kitchen Light (2C.79.48). Try #3 failed.
              Jul-15 16:32:25 Insteon Received a Direct ACK from Kitchen Light (2C.79.48): 2C 79 48 2C BA 5A 2B 00 00
              Jul-15 16:32:25 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:25 Insteon ..Got Hub Response 02 62 2C 79 48 0F 11 FF 06
              Jul-15 16:32:25 Insteon Received STX 0x50 (Raw Insteon Rec):2C 79 48 2C BA 5A 2B 00 00
              Jul-15 16:32:25 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:25 Insteon ..My XML buffer: 02622C79480F11FF0602502C79482CBA5A2B000000000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:32:23 Insteon Sending http://192.168.0.253:25105/3?02622C79480F11FF=I=3
              Jul-15 16:32:23 Insteon Sending command 02 62 2C 79 48 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:32:23 Insteon Did not receive a response from Kitchen Light (2C.79.48). Try #2 failed.
              Jul-15 16:32:19 Insteon Received a Direct ACK from Kitchen Light (2C.79.48): 2C 79 48 2C BA 5A 2B 00 00
              Jul-15 16:32:19 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:19 Insteon Received STX 0x50 (Raw Insteon Rec):2C 79 48 2C BA 5A 23 00 00 Debouncing repeat.
              Jul-15 16:32:19 Insteon Received STX 0x50 (Raw Insteon Rec):2C 79 48 2C BA 5A 2B 00 00
              Jul-15 16:32:19 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:19 Insteon ..My XML buffer: 02502C79482CBA5A2B000002502C79482CBA5A2300000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:32:17 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:17 Insteon ..Got Hub Response 02 62 2C 79 48 0F 11 FF 06
              Jul-15 16:32:17 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:17 Insteon ..My XML buffer: 02622C79480F11FF06000000000000000000000000000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:32:17 Insteon Sending http://192.168.0.253:25105/3?02622C79480F11FF=I=3
              Jul-15 16:32:17 Insteon Sending command 02 62 2C 79 48 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:32:17 Insteon Did not receive a response from Kitchen Light (2C.79.48). Try #1 failed.
              Jul-15 16:32:16 BLLAN Info Computer - Living Room Reciever --- 1 PING failure
              Jul-15 16:32:11 Insteon Received a Direct ACK from Kitchen Light (2C.79.48): 2C 79 48 2C BA 5A 2B 00 00
              Jul-15 16:32:11 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:11 Insteon Received STX 0x50 (Raw Insteon Rec):2C 79 48 2C BA 5A 2B 00 00
              Jul-15 16:32:11 Insteon ..Got Hub Response 02 62 2C 79 48 0F 11 FF 06
              Jul-15 16:32:11 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:11 Insteon ..My XML buffer: 02622C79480F11FF0602502C79482CBA5A2B000000000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:32:09 Insteon CAPIControl: Label=On, Value=100, ControlType=Button
              Jul-15 16:32:09 Device Control Device: Living Room Table Light to On (100) by/from: CAPI Control Handler
              Jul-15 16:32:09 Insteon Sending http://192.168.0.253:25105/3?02622C79480F11FF=I=3
              Jul-15 16:32:09 Insteon Sending command 02 62 2C 79 48 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:32:09 Insteon Setting status and value for device 2B.1F.59:1. Old status:0 Old Value:0, New Status:2 New Value:100
              Jul-15 16:32:09 Insteon Received a Direct ACK from Kitchen Counter Light (2B.1F.59): 2B 1F 59 2C BA 5A 23 11 FF
              Jul-15 16:32:09 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:32:09 Insteon ..Got Hub Response 02 62 2B 1F 59 0F 11 FF 06
              Jul-15 16:32:09 Insteon Received STX 0x50 (Raw Insteon Rec):2B 1F 59 2C BA 5A 23 11 FF
              Jul-15 16:32:09 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:32:09 Insteon ..My XML buffer: 02622B1F590F11FF0602502B1F592CBA5A2311FF00000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:32:09 Device Control Device: Kitchen Light to On (100) by/from: CAPI Control Handler
              Jul-15 16:32:08 Insteon Sending http://192.168.0.253:25105/3?02622B1F590F11FF=I=3
              Jul-15 16:32:08 Insteon Sending command 02 62 2B 1F 59 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:32:08 Insteon CAPIControl: Label=On, Value=100, ControlType=Button
              Jul-15 16:32:08 Device Control Device: Kitchen Counter Light to On (100) by/from: CAPI Control Handler
              turning them off:
              Jul-15 16:34:15 Insteon ..Got Hub Response 02 62 2F BC 48 1F 2E 00 00 09 80 00 00 00 00 00 00 00 00 00 00 49 06
              Jul-15 16:34:15 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:34:15 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:34:15 Insteon ..My XML buffer: 02622FBC481F2E0000098000000000000000000000490600000000000000 0000000000000000000000000000000000000000
              Jul-15 16:34:13 Insteon Sending command 02 62 2F BC 48 1F 2E 00 00 09 80 00 00 00 00 00 00 00 00 00 00 49 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:34:13 Insteon Setting status and value for device 2C.85.C1:1. Old status:100 Old Value:100, New Status:3 New Value:0
              Jul-15 16:34:13 Insteon Received a Direct ACK from Kitchen Gas Light (2C.85.C1): 2C 85 C1 2C BA 5A 2F 13 00
              Jul-15 16:34:13 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:34:13 Insteon ..Got Hub Response 02 62 2C 85 C1 0F 13 00 06
              Jul-15 16:34:13 Insteon Received STX 0x50 (Raw Insteon Rec):2C 85 C1 2C BA 5A 2F 13 00
              Jul-15 16:34:13 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:34:13 Insteon ..My XML buffer: 02622C85C10F13000602502C85C12CBA5A2F130000000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:34:11 Insteon Sending http://192.168.0.253:25105/3?02622C85C10F1300=I=3
              Jul-15 16:34:11 Insteon Sending command 02 62 2C 85 C1 0F 13 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:34:11 Insteon Checking for keypadlinc button sync on device 2F.BC.48 src index 4, SrcIsSyncTarget=True...
              Jul-15 16:34:11 Insteon Setting status and value for device 2F.BC.48:4. Old status:100 Old Value:100, New Status:3 New Value:0
              Jul-15 16:34:11 Insteon Received a Direct ACK from Living Room Keypad (2F.BC.48): 2F BC 48 2C BA 5A 23 00 88
              Jul-15 16:34:11 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:34:11 Insteon Received STX 0x50 (Raw Insteon Rec):2F BC 48 2C BA 5A 23 00 88
              Jul-15 16:34:11 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:34:11 Insteon ..My XML buffer: 02502FBC482CBA5A23008800000000000000000000000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:34:09 Insteon ..Got Hub Response 02 62 2F BC 48 0F 19 01 06
              Jul-15 16:34:09 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:34:09 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:34:09 Insteon ..My XML buffer: 02622FBC480F190106000000000000000000000000000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:34:07 Insteon Sending http://192.168.0.253:25105/3?02622FBC480F1901=I=3
              Jul-15 16:34:07 Insteon Sending command 02 62 2F BC 48 0F 19 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:34:07 Insteon Attempting to get a KPL LED status response from Insteon device 2F.BC.48
              Jul-15 16:34:07 Insteon Sending sync command 19 to linked responder device: Living Room Keypad Button D: Living Room Keypad Button D - Table Light (2F.BC.48)
              Jul-15 16:34:07 Insteon SyncResponderDevices called for device code: 32.73.D4:1
              Jul-15 16:34:07 Insteon Setting status and value for device 32.73.D4:1. Old status:100 Old Value:100, New Status:3 New Value:0
              Jul-15 16:34:07 Insteon Received a Direct ACK from Living Room Table Light (32.73.D4): 32 73 D4 2C BA 5A 2B 13 00
              Jul-15 16:34:07 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:34:07 Insteon ..Got Hub Response 02 62 32 73 D4 0F 13 00 06
              Jul-15 16:34:07 Insteon Received STX 0x50 (Raw Insteon Rec):32 73 D4 2C BA 5A 2B 13 00
              Jul-15 16:34:07 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:34:07 Insteon ..My XML buffer: 02623273D40F13000602503273D42CBA5A2B130000000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:34:05 Insteon Sending http://192.168.0.253:25105/3?02623273D40F1300=I=3
              Jul-15 16:34:05 Insteon Sending command 02 62 32 73 D4 0F 13 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:34:05 Insteon Sending sync command 19 to linked responder device: Kitchen Gas Light (2C.85.C1)
              Jul-15 16:34:05 Insteon SyncResponderDevices called for device code: 2C.79.48:1
              Jul-15 16:34:05 Insteon Setting status and value for device 2C.79.48:1. Old status:100 Old Value:100, New Status:3 New Value:0
              Jul-15 16:34:05 Insteon Received a Direct ACK from Kitchen Light (2C.79.48): 2C 79 48 2C BA 5A 2B 13 00
              Jul-15 16:34:05 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:34:05 Insteon ..Got Hub Response 02 62 2C 79 48 0F 13 00 06
              Jul-15 16:34:05 Insteon Received STX 0x50 (Raw Insteon Rec):2C 79 48 2C BA 5A 2B 13 00
              Jul-15 16:34:05 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:34:05 Insteon ..My XML buffer: 02622C79480F13000602502C79482CBA5A2B130000000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:34:04 Insteon CAPIControl: Label=Off, Value=0, ControlType=Button
              Jul-15 16:34:04 Device Control Device: Living Room Table Light to Off (0) by/from: CAPI Control Handler
              Jul-15 16:34:03 Insteon Sending http://192.168.0.253:25105/3?02622C79480F1300=I=3
              Jul-15 16:34:03 Insteon Sending command 02 62 2C 79 48 0F 13 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:34:03 Insteon Setting status and value for device 2B.1F.59:1. Old status:100 Old Value:100, New Status:3 New Value:0
              Jul-15 16:34:03 Insteon Received a Direct ACK from Kitchen Counter Light (2B.1F.59): 2B 1F 59 2C BA 5A 23 13 00
              Jul-15 16:34:03 Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
              Jul-15 16:34:03 Insteon Received STX 0x50 (Raw Insteon Rec):2B 1F 59 2C BA 5A 23 13 00
              Jul-15 16:34:03 Insteon ..Got Hub Response 02 62 2B 1F 59 0F 13 00 06
              Jul-15 16:34:03 Insteon Sending http://192.168.0.253:25105/1?XB=M=1
              Jul-15 16:34:03 Insteon ..My XML buffer: 02622B1F590F13000602502B1F592CBA5A23130000000000000000000000 0000000000000000000000000000000000000000
              Jul-15 16:34:02 Insteon CAPIControl: Label=Off, Value=0, ControlType=Button
              Jul-15 16:34:02 Device Control Device: Kitchen Light to Off (0) by/from: CAPI Control Handler
              Jul-15 16:34:01 Insteon Sending http://192.168.0.253:25105/3?02622B1F590F1300=I=3
              Jul-15 16:34:01 Insteon Sending command 02 62 2B 1F 59 0F 13 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              Jul-15 16:34:01 Insteon CAPIControl: Label=Off, Value=0, ControlType=Button
              Jul-15 16:34:01 Device Control Device: Kitchen Counter Light to Off (0) by/from: CAPI Control Handler
                #37
                automatic polling can flood the interface if you are polling devices too frequently. try reducing the polling frequency or the number of devices you poll.
                Mark
                HS3 Pro 4.2.19.5
                  #38
                  i am polling a few devices but i spread them with a few minutes between them.
                  device 1: every 7 minutes
                  device 2: every 25 minutes
                  device 3: every 13 minutes
                  and etc....
                    #39
                    according to your logs, if you search for "Did not receive a response from" you will see Kitchen Lights isn't responding to the polling. you might investigate why
                    Mark
                    HS3 Pro 4.2.19.5
