If you would have generated a report log I could tell you more, but the tap-link is only one way in this version of the plug-in. I have recently changed it so that if 2-way communication can not complete then the device will not be added. Try the hardware/completely reset PLC option.
Jon
Jon
Originally posted by danielperez
I tried to install the SDM and the Beta insteon 2.16 plugin manually (without the updater) and HS failed to communicate with the PLC. I went back to a previous HSPI_Insteon.dll and it worked. Then I used the updater install for 2.16 and then HS could see the PLC. I followed all instructions for the manual install carefully, but it read the wrong PLC version ID in that case. I tried resetting the PLC etc. but to no avail until I used the updater. Not sure what happened.
Now I also failed to control my switches. I started with no ini file, so it was a clean config. I tap-linked 3 devices and it added them, reading the address info without any problem. Then I went to read link information and got:
Reading remote link database record for device ID 01.14.D1 record # 1, attempt # 2...
and finally failed. Here is my log file info:
12/6/2006 11:46:21 PM Updater Starting installation of updates
12/6/2006 11:46:21 PM Updater Applying update: BETA Insteon Plug-in
12/6/2006 11:46:30 PM Updater Deleting file: C:\Program Files\HomeSeer 2\Docs\Insteon Beta 3 notes.pdf
12/6/2006 11:46:30 PM Updater Copying file: C:\Program Files\HomeSeer 2\Docs\Insteon RC2 notes.pdf
12/6/2006 11:46:35 PM Updater Package Install Message: Release notes for this plug-in have been copied to the HomeSeer DOCS directory (Insteon RC2 notes.pdf).
12/6/2006 11:46:52 PM Updater Package Install Message: The SmartHome Device Manager (SDM) is required to be installed. The setup program has been copied to the \BIN\Insteon directory of your system and the updater will run it now.
12/6/2006 11:46:53 PM Updater Copying file: C:\Program Files\HomeSeer 2\BIN\Insteon\SetupSmarthomeDeviceManager3-278.exe
12/6/2006 11:46:53 PM Updater Copying file: C:\Program Files\HomeSeer 2\HSPI_INSTEON.dll
12/6/2006 11:46:53 PM Updater Copying file: C:\Program Files\HomeSeer 2\Interop.SDM3Server.dll
12/6/2006 11:46:53 PM Updater Executing installer and waiting for it to finish: C:\Program Files\HomeSeer 2\updates2\BETA Insteon Plug-in0.0.2.16\SetupSmarthomeDeviceManager3-278.exe
12/6/2006 11:47:52 PM Updater Installation of updates completed
2/6/2006 11:47:54 PM Startup Checking for available plug-ins
12/6/2006 11:47:55 PM Info Found plug-in: X10 CM11A/CM12U, version: 1.0.1.0
12/6/2006 11:47:57 PM Info Found plug-in: HAI RC Thermostat, version: 1.0.16.0
12/6/2006 11:47:57 PM Info Found plug-in: Insteon, version: 0.0.2.16
12/6/2006 11:47:59 PM Info Found plug-in: MLHSPlugin, version: 1.1.0.90
12/6/2006 11:47:59 PM Info Found plug-in: Napco Gemini, version: 2.0.0.23
12/6/2006 11:48:00 PM Info Found plug-in: SmartHome PowerLinc USB, version: 1.0.0.7
12/6/2006 11:48:00 PM Info Found plug-in: SmartLinc Templinc, version: 2.0.0.1
12/6/2006 11:48:00 PM Info Found plug-in: Touchpad, version: 2.0.0.21
12/6/2006 11:48:04 PM Startup Restoring device status
12/6/2006 11:48:05 PM Startup Initializing Plug-Ins
12/6/2006 11:48:05 PM Info Initializing X10 Plug-in: Insteon On COM Port 1
12/6/2006 11:48:05 PM Info Initializing Plug-in: Insteon
12/6/2006 11:48:06 PM Insteon Connecting to SmartHome Device Manager (SDM) component...
12/6/2006 11:48:15 PM Insteon Insteon interface found containing firmware version 2.13 (Version 2 Revision 13)
12/6/2006 11:48:15 PM Info Finished initializing X10 interface Insteon
12/6/2006 11:48:16 PM Info Finished initializing infrared interface
12/6/2006 11:48:16 PM Info Initializing Plug-in: Insteon
12/6/2006 11:48:16 PM Info Finished initializing plug-in Insteon
For good measure I restarted HS again and could not read the devices. I also turned on detailed debug:
12/7/2006 12:32:15 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 15 9A 00 19 00'...
12/7/2006 12:32:18 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 15 9A 00 19 00'...
12/7/2006 12:32:21 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 15 9A 00 19 00'...
12/7/2006 12:32:24 AM Insteon Did not get any status response from 01.15.9A after 5 tries, can't update the device status.
12/7/2006 12:32:28 AM Insteon Edit Device Selected
12/7/2006 12:32:28 AM Insteon Edit Insteon Device # 3 Addr: 01.15.9A, Name:Hall, Location:Attic
12/7/2006 12:32:31 AM Insteon Read Device Links and Settings Selected
12/7/2006 12:32:31 AM Insteon Launching new BackgroundUpdate Thread with job type 2...
12/7/2006 12:32:31 AM Insteon In BackgroundUpdate Thread...
12/7/2006 12:32:31 AM Insteon Optimized Peek Remote Memory 01.15.9A:0032
12/7/2006 12:32:31 AM Insteon Optimized Peek Remote Memory reset MSB for 01.15.9A: 00
12/7/2006 12:32:34 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #1 FAILED)
12/7/2006 12:32:37 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #2 FAILED)
12/7/2006 12:32:39 AM Napco Gemini Status event received: 192, 15, 5 (Attic Motion): Zone Opened.
12/7/2006 12:32:39 AM Insteon Timed poll for Insteon device ID 01.14.D1 Unit code 1, Last contact 12/7/2006 12:31:38 AM. Polling interval of 1 min. reached, polling...
12/7/2006 12:32:39 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 D1 00 19 00'...
12/7/2006 12:32:40 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #3 FAILED)
12/7/2006 12:32:42 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 D1 00 19 00'...
12/7/2006 12:32:43 AM Napco Gemini Status event received: 194, 0, 5 (Attic Motion): Zone Closed.
12/7/2006 12:32:43 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #4 FAILED)
12/7/2006 12:32:44 AM Napco Gemini Status event received: 192, 15, 5 (Attic Motion): Zone Opened.
12/7/2006 12:32:45 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 D1 00 19 00'...
12/7/2006 12:32:46 AM Napco Gemini Status event received: 194, 0, 5 (Attic Motion): Zone Closed.
12/7/2006 12:32:47 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #5 FAILED)
12/7/2006 12:32:48 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 D1 00 19 00'...
12/7/2006 12:32:50 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #6 FAILED)
12/7/2006 12:32:50 AM Insteon Could not get data from remote device, no ACK for set MSB on remote peek to 01.15.9A
12/7/2006 12:32:50 AM Insteon Could not retrieve remote special value DefaultOnLevel from Insteon device 01.15.9A location 0x32
12/7/2006 12:32:50 AM Insteon Reading remote link database record for device ID 01.15.9A record # 1...
12/7/2006 12:32:50 AM Insteon Optimized Peek Remote Memory 01.15.9A:0FF8
12/7/2006 12:32:50 AM Insteon Optimized Peek Remote Memory reset MSB for 01.15.9A: 0F
12/7/2006 12:32:51 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 D1 00 19 00'...
12/7/2006 12:32:52 AM Napco Gemini Status event received: 192, 15, 5 (Attic Motion): Zone Opened.
12/7/2006 12:32:53 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #1 FAILED)
12/7/2006 12:32:55 AM Napco Gemini Status event received: 194, 0, 5 (Attic Motion): Zone Closed.
12/7/2006 12:32:55 AM Insteon Did not get any status response from 01.14.D1 after 5 tries, can't update the device status.
12/7/2006 12:32:55 AM Insteon Timed poll for Insteon device ID 01.14.C6 Unit code 2, Last contact 12/7/2006 12:31:53 AM. Polling interval of 1 min. reached, polling...
12/7/2006 12:32:55 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 C6 00 19 00'...
12/7/2006 12:32:56 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #2 FAILED)
12/7/2006 12:32:56 AM Napco Gemini Status event received: 192, 15, 5 (Attic Motion): Zone Opened.
12/7/2006 12:32:58 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 C6 00 19 00'...
12/7/2006 12:32:59 AM Napco Gemini Status event received: 194, 0, 5 (Attic Motion): Zone Closed.
12/7/2006 12:32:59 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #3 FAILED)
12/7/2006 12:33:01 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 C6 00 19 00'...
12/7/2006 12:33:02 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #4 FAILED)
12/7/2006 12:33:04 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 C6 00 19 00'...
12/7/2006 12:33:05 AM Napco Gemini Status event received: 192, 15, 5 (Attic Motion): Zone Opened.
12/7/2006 12:33:05 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #5 FAILED)
12/7/2006 12:33:07 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 C6 00 19 00'...
12/7/2006 12:33:08 AM Napco Gemini Status event received: 194, 0, 5 (Attic Motion): Zone Closed.
12/7/2006 12:33:09 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #6 FAILED)
12/7/2006 12:33:09 AM Insteon Could not get data from remote device, no ACK for set MSB on remote peek to 01.15.9A
12/7/2006 12:33:09 AM Insteon Failed to get remote link database record for Insteon device 01.15.9A record # 1.
12/7/2006 12:33:09 AM Insteon Reading remote link database record for device ID 01.15.9A record # 1, attempt # 2...
12/7/2006 12:33:09 AM Insteon Optimized Peek Remote Memory 01.15.9A:0FF8
12/7/2006 12:33:09 AM Insteon Optimized Peek Remote Memory reset MSB for 01.15.9A: 0F
12/7/2006 12:33:09 AM Napco Gemini Status event received: 192, 15, 5 (Attic Motion): Zone Opened.
12/7/2006 12:33:10 AM Insteon Did not get any status response from 01.14.C6 after 5 tries, can't update the device status.
12/7/2006 12:33:10 AM Insteon Timed poll for Insteon device ID 01.15.9A Unit code 3, Last contact 12/7/2006 12:32:09 AM. Polling interval of 1 min. reached, polling...
12/7/2006 12:33:10 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 15 9A 00 19 00'...
12/7/2006 12:33:12 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #1 FAILED)
12/7/2006 12:33:12 AM Napco Gemini Status event received: 194, 0, 5 (Attic Motion): Zone Closed.
12/7/2006 12:33:13 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 15 9A 00 19 00'...
12/7/2006 12:33:15 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #2 FAILED)
12/7/2006 12:33:17 AM Napco Gemini Status event received: 192, 15, 5 (Attic Motion): Zone Opened.
12/7/2006 12:33:17 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 15 9A 00 19 00'...
12/7/2006 12:33:18 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #3 FAILED)
12/7/2006 12:33:19 AM Napco Gemini Status event received: 194, 0, 5 (Attic Motion): Zone Closed.
12/7/2006 12:33:20 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 15 9A 00 19 00'...
12/7/2006 12:33:21 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #4 FAILED)
12/7/2006 12:33:23 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 15 9A 00 19 00'...
12/7/2006 12:33:24 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #5 FAILED)
12/7/2006 12:33:26 AM Insteon Did not get any status response from 01.15.9A after 5 tries, can't update the device status.
12/7/2006 12:33:27 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #6 FAILED)
12/7/2006 12:33:27 AM Insteon Could not get data from remote device, no ACK for set MSB on remote peek to 01.15.9A
12/7/2006 12:33:27 AM Insteon Failed to get remote link database record for Insteon device 01.15.9A record # 1.
12/7/2006 12:33:27 AM Insteon Reading remote link database record for device ID 01.15.9A record # 1, attempt # 3...
12/7/2006 12:33:27 AM Insteon Optimized Peek Remote Memory 01.15.9A:0FF8
12/7/2006 12:33:27 AM Insteon Optimized Peek Remote Memory reset MSB for 01.15.9A: 0F
12/7/2006 12:33:30 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #1 FAILED)
12/7/2006 12:33:34 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #2 FAILED)
12/7/2006 12:33:37 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #3 FAILED)
12/7/2006 12:33:40 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #4 FAILED)
12/7/2006 12:33:41 AM Insteon Timed poll for Insteon device ID 01.14.D1 Unit code 1, Last contact 12/7/2006 12:32:39 AM. Polling interval of 1 min. reached, polling...
12/7/2006 12:33:41 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 D1 00 19 00'...
12/7/2006 12:33:43 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #5 FAILED)
12/7/2006 12:33:44 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 D1 00 19 00'...
12/7/2006 12:33:46 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #6 FAILED)
12/7/2006 12:33:46 AM Insteon Could not get data from remote device, no ACK for set MSB on remote peek to 01.15.9A
12/7/2006 12:33:46 AM Insteon Failed to get remote link database record for Insteon device 01.15.9A record # 1.
12/7/2006 12:33:46 AM Insteon Reading remote link database record for device ID 01.15.9A record # 1, attempt # 4...
12/7/2006 12:33:46 AM Insteon Optimized Peek Remote Memory 01.15.9A:0FF8
12/7/2006 12:33:46 AM Insteon Optimized Peek Remote Memory reset MSB for 01.15.9A: 0F
12/7/2006 12:33:47 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 D1 00 19 00'...
12/7/2006 12:33:49 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #1 FAILED)
12/7/2006 12:33:50 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 D1 00 19 00'...
12/7/2006 12:33:52 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #2 FAILED)
12/7/2006 12:33:54 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 D1 00 19 00'...
12/7/2006 12:33:56 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #3 FAILED)
12/7/2006 12:33:57 AM Napco Gemini Status event received: 192, 15, 5 (Attic Motion): Zone Opened.
12/7/2006 12:33:57 AM Insteon Did not get any status response from 01.14.D1 after 5 tries, can't update the device status.
12/7/2006 12:33:57 AM Insteon Timed poll for Insteon device ID 01.14.C6 Unit code 2, Last contact 12/7/2006 12:32:55 AM. Polling interval of 1 min. reached, polling...
12/7/2006 12:33:57 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 C6 00 19 00'...
12/7/2006 12:33:59 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #4 FAILED)
12/7/2006 12:34:00 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 C6 00 19 00'...
12/7/2006 12:34:02 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #5 FAILED)
12/7/2006 12:34:02 AM Napco Gemini Status event received: 194, 0, 5 (Attic Motion): Zone Closed.
12/7/2006 12:34:03 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 C6 00 19 00'...
12/7/2006 12:34:05 AM Insteon No ACK for set MSB on remote peek to 01.15.9A (Try #6 FAILED)
12/7/2006 12:34:05 AM Insteon Could not get data from remote device, no ACK for set MSB on remote peek to 01.15.9A
12/7/2006 12:34:05 AM Insteon Failed to get remote link database record for Insteon device 01.15.9A record # 1.
12/7/2006 12:34:05 AM Insteon The database record for Insteon device 01.15.9A record # 1 could not be read after several tries, aborting.
12/7/2006 12:34:05 AM Insteon BackgroundUpdate Thread Complete...
12/7/2006 12:34:06 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 C6 00 19 00'...
12/7/2006 12:34:09 AM Insteon Calling DM: 'SendInsteonRaw=00 00 00 01 14 C6 00 19 00'...
So how can it read the device address and nothing else? Could this have something to do with the signallink RF install? I tried moving the signal links and reconnecting them, but that made no change. To be clear, the tap-link works and works really fast. I just can't control any devices or retrieve link tables.
