Originally posted by alevey
View Post
New Insteon Lighting Plug-In v1.2.0.1 (beta) for PLM
Mark
HS3 Pro 4.2.19.5
Originally posted by alevey View PostCool
One more question... I have installed about 10 brand new v2 (Firmware 27) dimmers. They all work fine but it seems that the ramp rate and dim level do not set from the plugin, even though it says it does?Mark
HS3 Pro 4.2.19.5
imissnixon
SDM dll
Originally posted by mnsandler View PostI don't have a copy of the SDM which is required to build a version for the PLC. If someone can post a copy of the SDM3Server.dll file, i think that is all i need.Attached Files
Mark,
How did you wire your Insteon bridge?
I read the instructions on Smarthome and it saids to connect the bridge to two breakers on one side. If this device is supposed to bridge between the two phases why is it connected only to one phase?- Pete
Pete:
Most split phase panels in the US are setup so that every other breaker in the panel is a different phase. So wiring it on the same side will work just fine.Marty
I actually wired mine in parallel with my x10 c/r.Mark
HS3 Pro 4.2.19.5
Thanks guys. Will wire mine in parallel to the X10 c/r. I spent some time a while ago trying to "even" out the the two sides without an amp probe but rather just the values of the breakers and assumed via a visual that the breakers only clamped on to one side (one phase).- Pete
So far so good with PLM version and 105 insteon devices. I love the UI with version number and easy to read format, and especially the cumulative communication efficiency.
Can you further describe the keypad 6 button / 8 button fix? I have both types of keypads operating but wasn't aware of any problems with the earlier plug in.
Originally posted by jono View PostSo far so good with PLM version and 105 insteon devices. I love the UI with version number and easy to read format, and especially the cumulative communication efficiency.
so i added the code to correctly identify newer i2 KPLs (in 8 btn mode).
i1 and i2 are shortnames for insteon protocol 1 and 2. the newer smarthome devices are starting to use i2 which is pretty incompatible with i1. the plugin was developed around i1. I think this is where the heavy lifting is going to be as this plugin evolves.Mark
HS3 Pro 4.2.19.5
Originally posted by sqhughes View PostI am using the latest PLM version and cannot seem to make changes to groups or add groups. I tried deleting an old one and that seemed to work.
Scott
are there any errors in the log or is an insteon report.log generated.
please post any errorsMark
HS3 Pro 4.2.19.5
With detailed debugging, all I get is this when trying to edit a group:
11/19/2009 6:24:23 PM ~!~Insteon~!~Group index 1 was selected.
11/19/2009 6:24:36 PM ~!~ECHO~!~Echo for Den Motion 12; No Echo (5 mins, 40 secs)
11/19/2009 6:24:47 PM ~!~UltraM1G Info~!~Zone 014 [Kitchen Motion] is Violated
When I select "save changes and reprogram group" it just takes me back to the main configuration page.
Originally posted by sqhughes View PostWith detailed debugging, all I get is this when trying to edit a group:
When I select "save changes and reprogram group" it just takes me back to the main configuration page.Mark
HS3 Pro 4.2.19.5
i didn't see anything unusual in your ini. but please make sure there are no spaces in any of the "Participants" keys in the [Group xx] sections
is there a recent insteon report.log file in the config folder. if so, please email it to me; the PMs seem to mess up the files.
did you have Detailed Debugging turned on when you tried the Group Add; the ini indicated only "debug log entrie"Mark
HS3 Pro 4.2.19.5
Recieved and installed Insteon bridge today. I had a double duplex metal box adjacent to the fuse panel with one duplex outlet on it. I remove the single duplex cover and replaced it with a double duplex cover so that I could install the bridge in the same metal box. It also allowed me to feed the wire leads into the fuse panel with about 2 inches on each lead and enough to add a couple of wires to the breakers. I also purchased two Insteon appliance modules. I don't recall what the box said for the other two that I have in the home but this box (for the appliance module) states that its also an Insteon repeater. Next endeavor is the installation of a couple of UPB controllers and a couple of wall switches to test.- Pete
