Originally posted by leerogers
View Post
Insteon I/O Linc
Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postsorry, not an x10 powerflash, but an actual power outage
Guest
Hi Lee,
Do you get the extended Insteon device menu after you installed the dll from mnsandler?
My Edit Device menu is a lot shorter and does not have the options for setup.
The IOLinc is not recognized, shows as Unknown Device 0700. See below:
Insteon Device ID: 12.F8.16
Device Name:
Device Location:
Device Type: Unknown Device Type 0700
Firmware Version: 36 [Comm Reliability: 100%]
Resume dim mode: False
Default local on level: 100%
Polling Interval (Minutes, 0=None):
------ Link table present in remote device: ------
Link# 1 - Unknown has local control reporting to HomeSeer
Link# 2 - Unknown is controlled by HomeSeer (Using Insteon Link# 254) HomeSeer 'All Devices Group' - Command: On
That's about it.
you need a more current version of the plugin. v1.4.2 is postedMark
HS3 Pro 4.2.19.5
Confused
Im a little confused after reading through this fourm. I have a 2450 and HS Pro. What i want to do is used the output on the 2450 for a door strike ( already in use) and eventually use the input for a keypad. As it looks i can not use both at the same time? Is this correct?
Rob
Originally posted by Rob2791 View PostIm a little confused after reading through this fourm. I have a 2450 and HS Pro. What i want to do is used the output on the 2450 for a door strike ( already in use) and eventually use the input for a keypad. As it looks i can not use both at the same time? Is this correct?
Rob
http://wiki.smarthome.com/index.php?title=2450_Manual
how is the keypad going to affect the 2450 via the input sensor? it it suppose to open the door strike?Mark
HS3 Pro 4.2.19.5
doramider7
Originally posted by leerogers View PostSounds like a reliability issue on my side but sometimes, the keypadlinc or Homeseer doesn't see the event. It doesn't happen very often but would love to be able to poll the 2450 for status
__________________________
ipad downloads
download ipad books
Originally posted by shermbb View PostFor those of us that do not have the isy or the additional Insteon plugin, is there a command that I can send via VB script to ping the device for a status (like the EZIO2x4 or EZIO8Sa devices)?
you need a plugin that can communicate with a plm to talk to the iolinc. hs can't send native insteon cmds by itself.
if you use the free insteon plm plugin, you can send a cmd set 0x19, 0x00 to get the relay status and 0x19, 0x01 to get the sensor statusMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postwhat is your setup? what plm and insteon plugin are you using
Would the iolinc device have to be registered in similar fashion as the devices within Insteon_ExtDevSupport.vb (currently have 3 EZIO devices, 4 motions sensors, and 1 EZFLORA), or would a command set for the sensor status force HS to update the sensor reading?
Would I use a hs.plugin("Insteon").ExtDev_TransmitToExternalDevice command set, execx10, or other command?
Originally posted by shermbb View PostThanks for the discussion Mark. I am using HS2.5 with the free Insteon plugin, and need to be able to ping the iolinc's sensor status. I can poll the relay status with no problems. I currently just capture the sensor status with a virtual device, but HS only catches the broadcast ~80% of the time.
use hs.plugin("Insteon").TransmitDeviceCommand to send a custom cmd but you won't get a response back so i don't know how you will get the status value you need.
just so you know, the newer plugin (1.5+) supports the input sensor and output relay as separate hs devices that can be polled independently.Mark
HS3 Pro 4.2.19.5
Hi Mark,
if I purchase the Insteon I/O garage linc, is it now fully supported in the latest insteon plugin and HS?
I would be buying 2 since I have 2 garage doors.
http://www.smarthome.com/74551/I-O-L...tus-Kit/p.aspx
Let me know
Raven
Let me know
Raven
when you register the device with the plugin, you will get two hs devices:
1. one represents the output relay (used to trigger open/close)
2. one that represents the input sensor (used to monitor the door)
you should thoroughly read the smarthome docs for setting up the iolinc with a garage door.
good luckMark
HS3 Pro 4.2.19.5
I recently purchased the I/O Linc 2450 and I have been unable to link it with the PLM. My setup is a 2413U controller, 2443 access point, several 2476S switches and the I/O Linc 2450. The log show that during linking that it is able to get the op flags but is unable to read the device properties. I contacted Insteon Gold Support and they suggested that since I am have the newest 2450 that it may not be compatbile with my Insteon plugin. The 2450 is v1.8 and the plugin is v1.5.5.0.
I have tried using it on several outlets, including the same outlet that the PLM is plugged into. The log shows:
7/22/2011 2:05:04 PM ~!~Insteon~!~Attempting to add Device 17.D5.81
7/22/2011 2:05:04 PM ~!~Insteon~!~Calling PLM_AddID for 17.D5.81 1 True
7/22/2011 2:05:05 PM ~!~Insteon~!~Sending Insteon ID Broadcast for '17.D5.81'
7/22/2011 2:05:08 PM ~!~Insteon~!~Got Op Flags response from Insteon ID 17.D5.81, Op Flags 00=02
7/22/2011 2:05:08 PM ~!~Insteon~!~The device properties could not be read. Communication failure. The device was not added.
What could be causing this problem? Is it a bad I/O linc or a plugin in problem?
