Originally posted by fisherk
View Post
same message in the generated error file. It still references COM6 but I have Com4 in the ini file. The computer has com4 in the hardware settings for the Insteon....
Insteon Plug-in Error Log Generated 8/3/2013 4:34:07 PM
-----------*Error Message*----------------
Error: Error in PLM_SendHex: A device attached to the system is not functioning.
-- Details System.IO.IOException: A device attached to the system is not functioning.
at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str)
at System.IO.Ports.SerialStream.EndWrite(IAsyncResult asyncResult)
at System.IO.Ports.SerialStream.Write(Byte[] array, Int32 offset, Int32 count, Int32 timeout)
at System.IO.Ports.SerialPort.Write(Byte[] buffer, Int32 offset, Int32 count)
at HSPI_INSTEON.HSPI.PLM_SendHex(String CmdIn, String Data, Int32 ExtraBytesExpectedBack, Int32& FailCode, Boolean ACKBeforePayload, Boolean NAKIsOk, Int32 iForcedSettleTime) -- 8/3/2013 4:34:07 PM
--------*Initialization Log*--------------
8/3/2013 4:34:06 PM - Host System: HomeSeer 2.5.0.52
8/3/2013 4:34:06 PM - Plugin: HSPI_Insteon.DLL - HYBRID PLM VERSION 1.1.52.1 In PLM Mode
8/3/2013 4:34:06 PM - RegisterCallback Completed
8/3/2013 4:34:06 PM - Enter InitIO
8/3/2013 4:34:06 PM - Enter InitPlugin
8/3/2013 4:34:06 PM - Global initialization of plug-in required, starting up.
8/3/2013 4:34:06 PM - Initializing Insteon hardware interface...
8/3/2013 4:34:07 PM - Sending command 02 60 to PLM, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
8/3/2013 4:34:07 PM - ***:Error in PLM_SendHex: A device attached to the system is not functioning.
-----------*Pre-Error Log*----------------
--------*End Pre-Error Log*--------------
--------*Start C:\Program Files\HomeSeer HS2\Config\Insteon.ini*--------------
[Config]
PortType=USB
GroupBaseCode=^
LastInterfaceAddress=1E.4D.71
NumDevices=12
DeviceBaseCode=]
MaxHops=2
NumRetries=5
WaitTimeout=5
DetailedLog=1
DoCleanups=1
InterfaceCapability=5
UseLocation2=0
DisablePolling=0
SortDeviceLinks=0
NumInterfaceLinks=69
InterfacePort=COM6
InterfaceModel=
[Device 1]
DeviceID=1F.0A.EB
DeviceName=Garage Door
DeviceLocation=Garage
PollingInterval=0
DeviceType=0700
FirmwareVer=41
DatabaseDelta=1
LinksDownloaded=1
EEValues=ClosureTime=15,OpFlags1=154,OpFlags2=0
LastContact=8/3/2013 12:47:54 PM
