For those who use it, BeakerStat for HS3 is nearly complete and will be available soon so you have control of your Filtrete/Radio Thermostat WiFi thermostats.
Upgrading from HS2 to HS3
Originally posted by Rotech View PostWould like to take the plunge, but it seams so scary, if I loose control of my existing setup.
Originally posted by Rupp View PostI wouldn't recommend moving a production setup to HS3. It's a first release beta and been released for testing but will be a while before all plugins are available from all parties. If you want to play load HS3 for testing but keep your HomeSeer 2 install until your plugins have been release and fully tested.
If I download Hs3 just to play with it, will it affect any behavior of my existing setup? Also if you transfer any existing plugins that work with HS3 do you need to disable the one in HS2?Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
z-stick will not initialize
I have taken my working z-stick from hspro, stopped the hspro software, started hs3 and set up the interface with the correct com port, but I get
Interface init failed: No response from controller. I have resarted the computer but same result.
Are we able to import the nodes from the controller or do we need to reset the z-stick and start again (I hope we can import).
Has anyone tried the z-stick and have it working?
Win.2003 OS, HS3
Originally posted by ozinnewy View PostI have taken my working z-stick from hspro, stopped the hspro software, started hs3 and set up the interface with the correct com port, but I get
It sounds like the problems I had.
Look at the file rights for C:\Program Files\Homeseer HS3\Config\Z-Wave.ini. You proberly need write on that file.
I made a bugzilla (and wrote far to fast. :-) ) http://homeseer.com/bugzilla/show_bug.cgi?id=476
z-stick error
Finally got my z-stick working thanks to mhn's suggestion. However when I try to import my devices I get the following error:
Error: Error, your interface is not Serial API version 4 or higher - the Z-Wave plug-in only works with newer Z-Wave interfaces.
Finished with Z-Wave device synchronization.
I have the latest firmware, I guess we need to wait for an update to the z-stick firmware??
Update:
I just enabled the z-stick on hspro and it reports it has Serial Z-Wave Serial API Version 5.
Is anyone using the z-stick with HS3 with any success?
Where to add a new node?
Right now I don't have any nodes to control in HS3
Z-wave problems, this is from the log, what does it means?
9:30:33.666 Z-Wave Error Unknown error building the Z-Wave Version Information
9:30:33.559 Z-Wave This Z-Wave PC Controller is Type: ZW_LIB_CONTROLLER_STATIC
9:30:33.559 Z-Wave Warning This Z-Wave PC Controller Library Version is: Z-Wave 2.78 (Unknown-Error)
9:30:33.559 Z-Wave Error Unknown error building the Z-Wave Version Information
9:30:33.447 Z-Wave Controller firmware version: 0.0
9:30:33.444 Z-Wave Found 41 Z-Wave nodes in interface node ID 1
9:30:33.444 Z-Wave Z-Wave interface node ID: 1, Home ID: 014CDFAE
9:30:33.444 Z-Wave Z-Wave Serial API version: 5
9:30:32.156 Z-Wave Getting node information from controller...
9:30:32.000 Z-Wave ----------------------------------------------------------------------
9:30:32.000 Z-Wave Initializing Z-Wave interface Z-Stick uppe (Aeon Labs Aeotec Z-Stick) on COM4
9:30:31.998 Z-Wave ----------------------------------------------------------------------
9:30:31.998 Z-Wave ============================================================ ==========
9:30:24.938 Z-Wave Exiting COM Device Thread
9:30:05.778 Z-Wave Starting 'Z-Wave Health' Process Starter...
Log this in bugzilla at homeseer.com/bugzilla
Originally posted by lhfarm View PostI can't get HS3 to communicate with an old CM11a. I'm sure the edgeport USB is working (tested it with my TEMP08). New box running Win7 64. HS2 is NOT installed on this box.
Where should we be posting questions and problems?
Barry
