Well I have succeeded in getting it all working without running a restore so far. Now I'm hoping its not the restore when it breaks.
HS3 Linux Installation Instructions
Try this:
apt-get install libmono-system-data-datasetextensions4.0-cil
which is referenced here:
File list of package libmono-system-data-datasetextensions4.0-cil in sid of architecture all- Pete
Good news Jim!
What restore? Database restore?
I have not attempted to migrate from a Windows HS3 to a Linux HS3 cuz I have always used Linux for HS3.
For testing HomeSeer I just copy the Linux HomeSeer directory to wherever.
Lost my connection to the Homeseer forum for a bit just now.
I rebooted my Jessie RPi2 build and all is fine now.
That said I am done doing this (I keep writing this) so will start a new Jessie Lite build from scratch and if that doesn't work then going back to Wheezy on the RPi2.
Note that this Jessie build RPi2 is just a Z-Wave slave (and x10 and UPB slave) / 1-wire hub and my Zee-2 HS3 lite is running on Ubuntu 16.04 64 bit server on the Xi5A.
Might make the Pine64 (also running Ubuntu 16.04 64 bit) the official Z-Wave slave and make the RPi2 something else or try an RPi3 (but I have no interest in the integrated Blue Tooth or WLAN stuff on the board - do want it to run Jessie in 64 bit mode though).Last edited by Pete; October 25, 2016, 11:34 PM.- Pete
Originally posted by Pete View PostGood news Jim!
What restore?
Here I just copy the HomeSeer directory as a backup to my Homeseer build.
mono install for Raspbian Jessie Lite 4.4
I just finished doing a re-installation and the below the install method I used.
sudo -i
apt-get install mono-vbnc
apt-get install libmono-system-web4.0.cil
apt-get install libmono-system-design4.0.cil
apt-get install libmono-system-web-extensions4.0-cil
apt-get install libmono-system-runtime-caching4.0-cil
apt-get install flite
apt-get install aha
I received the error related 'System.Data.DataSetExtensions.dll' error once on an old build of jessie that I had. My notes say that i tried installing mono complete which made my zwave equipment nearly unusable. I did more research on the mono site and found that the error message is linked to mono 3.8 dependencies that are not present in the mono 4 install. I have a post somewhere on here where on the homseer boards where I pointed out that I found that if I ran:
sudo -i
apt-get install mono-xsp4
the error message stopped. on my current HS3 server build a ran the above in addition to the rest of the apt-get commands that Pete pointed out (save for mono complete) and I have not seen that error.
Well that when my problem starts!
I copied the HomeSeer folder (as a restore) over and after that my Script errors return.
When I started with only an empty fresh install on the trail of hs3 I created a script and it was fine along with the startup script. After I run the restore or copy over the HomeSeer file directory and start it up my errors are there.
That is odd.
I have always backed up HomeSeer directory when updating for the quickie return if I have an issue.
Yup; here just throw the Mono kitchen sink to it and it worked for me. (mono-complete and what Rich posted).
Note that here I am still running HS3 HS3 Pro and lite Edition 3.0.0.291 (Linux) and Z-Wave plugin version 3.0.1.80.- Pete
And Z-Wave plugin version 3.0.1.80.
But Fresh install including installing the apps (but not all the config files) it works. I'm hoping this isn't some windows to Linux issue. I have been running windows for around a year and just moved to linux to test a few weeks ago and just yesterday is when i dropped windows completely and moved to linux everything works fine except for the only two devices I control via scripts or http commands. My Roomba and Blueiris Profiles.
Originally posted by Kerat View Postnow that is interesting. So, you are running mono complete or not? Also have you checked the permissions on the restored directory (command should be "ls -al"). if you are running mono on startup with a service account have you confirmed that the service account is either the object owner or a member of the group that has ownership of the files?
Now permissions..... You might be on to something there. I need more help ro instructions to check/fix.
I only run as root user, not Homeseer user.
This is what I use for auto startup, but even the shut down in this has never worked right as it uses the scripting that doesn't work.
http://board.homeseer.com/showpost.p...36&postcount=5
The fix for this was (posted by Rich) to use Mono 4.X so the import from the Windows DB to Linux DB would work.
I updated my Linux builds from Mono 3.12 to 4.X and it messed up my events such that I had to delete them and reconfigure them on my HS3 Pro and lite machines.
Here always shut down HS3 via the HS3 GUI. Some plugins take a long time to shut down.- Pete
Originally posted by Pete View PostI'm hoping this isn't some windows to Linux issue
I updated my Linux builds from Mono 3.12 to 4.X and it messed up my events such that I had to delete them and reconfigure them.
Except it isn't so far.
Originally posted by integlikewhoa View PostYes complete mono everything I can find to run.
Ok where is your HS3 folder?
