I have created a new plugin for controlling Philips Hue lights.
This is the release 1.0.4.1. It is available in the Manage plugins list of HS3
For further questions or updates go to this forum
Please note that installation has changed to HS3 standard methodlater development: (if I can do it..)
- Seperated music module (microphone based), to use on computer in different room then HS3 server to have disco effects
- Ability to point the program to a slideshow photo and adjust colors of lamps accordingly in a configurable way
- whatever more comes in mind - or from you!
If you experience any problems, please let me know on the Homeseer board or drop me an email at wim at vuyk.info.
Documentation is in the zip file.
You can download the plugin through the HS3 Manage plugins interface (available soon)
*update* bug with group "All Lights" is solved, should be working correct now, please download the updated version for this issue
Changes since 0.9.2.0:
* Solved the message "Unknown setting:Refreshrate"
* Added support for LLC010
* Solved possible issue with runrise and sunset animation when animation would start within the hour from the end time
* Solved "Collection was modified; enumeration operation may not execute." This should not occur anymore now.
Changes in 1.0.4.1
* solved issue with Scene renaming
* solved issue when bridge is not found
* added updating Lifetime usage per light
* added LifetimeReport as scriptcommand
* solved issue with bridge device updating while animation is running
* added Lifetime usage information to properties of lights
* added common lifetime information from Philips to every device
This is the release version. Further updates will be published here
Wim
Changes in 1.0.4.1
Wim
