Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3/PRO Beta Releases
HS3/PRO Beta Releases Discussion area for the beta releases of HomeSeer HS3 and HS3PRO software
Old April 4th, 2015, 07:29 PM
AbMagFAb AbMagFAb is offline
Post Current Linux build? New beta Z-Wave Linux 216 doesn't load
I'm running .210 Z-Wave, and my Z-Net just updated to .10, and now I'm getting really weird behavior (all was working fine before).
What's the current Linux build? I'm running .149 with the .152 extracted over it.
And is there any chance the kind folks at HomeSeer will actually keep a sticky post that is findable with the current Linux build? It's crazy how hard we have to work to find anything!
Old April 4th, 2015, 07:40 PM
Pete's Avatar
Pete Pete is offline
Here running:
Z-Wave 3.0.0.216
HS3 Pro Edition 3.0.0.152 (Linux)
Zee is running:
Z-Wave 3.0.0.216
HS3 ZEE Edition 3.0.0.162 (Linux)
Automator
Old April 4th, 2015, 07:43 PM
Originally Posted by Pete View Post
Here running:
Z-Wave 3.0.0.216
I'm running on a Mac too, if that makes a difference.
Did you do the .216 update through the UI, or did you download and install it manually?
When I do 216 through the UI, I end up with 3 weird windows opened on my server, with one that has a "Cancel" button (that does nothing when I press it). I need to "shutdown" and restart to make them go away.
Any advice?
Old April 4th, 2015, 07:49 PM
Pete's Avatar
I did the update to .216 via the UI with no issues.
Here running HS3 Pro on Ubuntu 14.04 64 bit.
Old April 4th, 2015, 10:19 PM
Well, I ran it through FireFox, and it worked. Seems weird that would make any difference?
Also, since I've been moving my Z-Wave network from my old Z-Troller/PC to my new Z-Net/Mac, I hadn't done a full optimize of my new network. Doing that seems to have resolved most of the weirdness also. Some strange issues with some devices that just won't be recognized at all in an add or remove, but I'll try again tomorrow once things settle in.
Any update on a place to get the most current Linux builds?
Old April 4th, 2015, 11:40 PM
Pete's Avatar
I never really look as its been running fine for me. Today updated the Z-Wave stuff to test out Z-Wave +.
I did see a couple of devices that were not recognized. I scanned them afterwards and the devices were recognized fine.
Remote load linux Z-Wave plugin on Windows HS mathd HomeSeer Z-Wave Plug-in 9 March 8th, 2017 06:23 AM
HS3 Linux build 3.0.0.94 is available rjh HS3/PRO Beta Releases 31 March 5th, 2015 12:17 PM
HS3 Linux build 3.0.0.83 is available rjh HS3/PRO Beta Releases 5 April 28th, 2014 02:56 PM
HS3 Linux build 3.0.0.55 is available rjh HS3/PRO Beta Releases 3 January 18th, 2014 10:53 PM
HS3 Linux build 3.0.0.54 is available rjh HS3/PRO Beta Releases 21 January 18th, 2014 10:43 AM
