Originally posted by kevini
View Post
HS3 Insteon Plug-In Version 3.0.5.88 Beta (Win & Linux)..In Beta section of Updater
Originally posted by mloebl View PostJust noticed the same thing here too.
please put the leak sensor into linking mode and reprogram the links just to make sure.
please enable detailed logging and then check the log around the time you expect the heartbeat. I'm curious if the leak sensor is sending a msg that the plugin isn't interrupting.Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View PostStrange, I'm running .43 myself and got a heartbeat from my leak sensor "Yesterday 11:58:22 PM". I have an action to tell me when a heart beat is missed, and i haven't missed one recently.
I'll provide the log info as soon as it comes in. It did not report at the time I was expecting it in the logs (9:27:18am) PT.
On closer inspection of the logs, The leak sensor did report this morning
You can see it in the Raw incoming message below but the plug-in seems to ignore it. The Device ID is: 21.7B.29
Dec-07 9:06:16 AM Insteon Received STX 0x50 (Raw Insteon Rec):2C 74 92 00 00 04 CB 13 04
Dec-07 9:06:16 AM Insteon ProcessCustomBroadcast: Device Kitchen/Dining Backdoor Sensor (2C.74.92) sent heartbeat with cmd 13
Dec-07 9:06:16 AM Insteon Setting status and value for device 2C.74.92:1. Old status:0 Old Value:0, New Status:3 New Value:0
Dec-07 9:06:16 AM Insteon Setting status and value for device 2C.74.92:4. Old status:0 Old Value:0, New Status:2 New Value:100
Dec-07 9:06:16 AM Event Event Trigger "Alerts Reset Counter on receiving Backdoor Sensor HeartBeat"
Dec-07 9:06:16 AM Insteon Setting status and value for device 2C.74.92:4. Old status:100 Old Value:100, New Status:3 New Value:0
Dec-07 9:06:17 AM Insteon Received STX 0x50 (Raw Insteon Rec):2C 74 92 00 00 04 CB 13 04 Debouncing repeat.
Dec-07 9:06:17 AM Insteon Received STX 0x50 (Raw Insteon Rec):2C 74 92 00 01 04 CB 13 04
Dec-07 9:06:17 AM Insteon Received STX 0x50 (Raw Insteon Rec):2C 74 92 13 00 04 CB 06 00
Dec-07 9:06:18 AM Insteon Received STX 0x50 (Raw Insteon Rec):2C 74 92 13 00 04 CB 06 00 Debouncing repeat.
Dec-07 9:08:19 AM Insteon Received STX 0x50 (Raw Insteon Rec):21 7B 29 00 00 04 C7 11 04
Dec-07 9:08:20 AM Insteon Received STX 0x50 (Raw Insteon Rec):21 7B 29 00 00 04 C7 11 04
Dec-07 9:08:20 AM Insteon Received STX 0x50 (Raw Insteon Rec):21 7B 29 11 00 04 C7 06 00
Dec-07 9:08:22 AM Insteon Received STX 0x50 (Raw Insteon Rec):21 7B 29 11 00 04 C7 06 00
Dec-07 9:13:21 AM Z-Wave Device: House Garage Temperature Set to 16.4 (C)
Dec-07 9:13:21 AM Z-Wave Device: House Garage Luminance Set to 46 (%)
Dec-07 9:16:14 AM Insteon Received STX 0x50 (Raw Insteon Rec):2C 71 EA 00 00 04 CB 13 04
Dec-07 9:16:14 AM Insteon ProcessCustomBroadcast: Device Garage Side Door Sensor (2C.71.EA) sent heartbeat with cmd 13
Dec-07 9:16:14 AM Insteon Setting status and value for device 2C.71.EA:1. Old status:0 Old Value:0, New Status:3 New Value:0
Dec-07 9:16:14 AM Insteon Setting status and value for device 2C.71.EA:4. Old status:0 Old Value:0, New Status:2 New Value:100
Dec-07 9:16:14 AM Event Event Trigger "Alerts Reset Counter on receiving Garage side door Sensor HeartBeat"
Dec-07 9:16:14 AM Insteon Setting status and value for device 2C.71.EA:4. Old status:100 Old Value:100, New Status:3 New Value:0
Dec-07 9:16:14 AM Insteon Received STX 0x50 (Raw Insteon Rec):2C 71 EA 00 00 04 CB 13 04 Debouncing repeat.
Dec-07 9:16:14 AM Insteon Received STX 0x50 (Raw Insteon Rec):2C 71 EA 00 01 04 CB 13 04
Dec-07 9:16:14 AM Insteon Received STX 0x50 (Raw Insteon Rec):2C 71 EA 13 00 04 CB 06 00
guys, what is the fw of your leak sensor? mine is fw 89. this may be the differenceMark
HS3 Pro 4.2.19.5
Originally posted by kevini View PostMine is .41
you may need to delete and register the leak sensor
the new heartbeat address should end with ":4". it may be ":2" before the updateMark
HS3 Pro 4.2.19.5
Originally posted by kevini View PostWorking perfectly again. Thanks Mark. As you expected the new device is :4 and it resets fine!Mark
HS3 Pro 4.2.19.5
Originally posted by joey52685 View PostTake a look at WinSCP for managing files on a Linux box from Windows. It connects using SSH just like Putty so there's no additional setup needed. Just choose SCP from the drop down list when you're connecting.
Originally posted by joey52685 View PostJust upgraded to .44 to take advantage of the ability to edit on/ramp levels in existing links. So far everything is working great.Mark
HS3 Pro 4.2.19.5
