Go Back   HomeSeer Message Board > Analog & Digital IO Device Plug-ins > Analog & Digital IO Discussion > SimpleHomeNet Plug-in
SimpleHomeNet Plug-in Discussions related to SimpleHomeNet Plug-in for HomeSeer
Old October 13th, 2013, 09:41 PM
hurry4it hurry4it is offline
HS3 Beta SimpleHomeNet Plugin v2.0.0.0
The SimpleHomeNet Plugin has been upgraded to version 2.0.0.0 which is compatible with HS3. The plugin is available in the HS3 updater and includes all features of version 1.0.2.2.
New Features:
- Add/Remove individual HS devices
- New error messages when Insteon messages fail to transmit
Changes:
- Minor bug fixes
Requirements:
- Requires mnSandler Insteon Plugin version 3.0.1.3 or greater
- Insteon plugin must be enabled prior to enabling the SimpleHomeNet plugin
Please let me know if you experience any issues with the plugin and post a copy of the HS log with debug logging enabled.
Adam
Old September 1st, 2014, 01:08 PM
bilesb's Avatar
bilesb bilesb is offline
Detailed Instruction Locations.
Coming Soon:
- Detailed instructions for use and operation of the SimpleHomeNet
- Support for 1-wire temperature sensor with EZIO8SA
Thanks. I am very interested in the Detailed instructions you have for the SimpleHomeNet. I have a EZIO40 and I am trying to get it working with HomeSeer version 3.0.0.96. Some type of instructions would be very useful. Where can I find these instructions?
Bruce
Old September 2nd, 2014, 05:15 PM
Bruce,
I worked up the instructions several months ago, but it appears that I never posted them. I'm searching for it now and will post it as soon as I can find it. If I am unable to find it, I'll need to recreate it which may take a couple days.
Adam
Old June 22nd, 2016, 08:38 AM
januszczyk januszczyk is offline
Beta Available for Linux/Mono?
Hi Adam,
So I'm finally getting around to moving my HS2 setup (complex) to HS3. Part of this is to move from WinXP to Ubuntu Linux. However in the HS3 Updater I cannot find the SimpleHomeNet plugin. Does this imply it's Windows only?
Also did you ever find the documentation?
- Jeff
Old June 23rd, 2016, 09:48 PM
Jeff,
I don't have a Linux setup to test with and so the plugin currently only supports Windows. Also, I was not able to find the documentation, but the plugin is very straight forward to use. If you run into any problems, let me know, and I can help solve them.
Adam
Old June 23rd, 2016, 11:52 PM
mikaluch's Avatar
mikaluch mikaluch is offline
Mention simple and I'm intrigued. What does the plugin do? I'm on linux so it's not in the updater. If you had a linux version or expect it would work as is and it is simple and useful I know where you could find free testers. Wow. That last sentence reads like a poorly written event.
The user's going to pick dancing pigs over security every time.Bruce Schneier
My Goal: Don't be that user.
My Ride: Lubuntu 14.04|Antec Cube case|MSI A68HM Grenade MB|AMD A4-7300 4.0 GHz|4 Gb DDR3 1600 MHz|Patriot Blaze SSD
The Hocus-Pocus: HS3|Z-wave|Sandler Insteon|X10|JowiHue|Tasker|BLLAN|WeatherXML|ImperiHome
Widgets and Doohickeys:
Insteon PLM|HomeSeer Z-stick+|Amazon Echo, Dot|4k Fire TV|Harmony Hub|Hue hub and lighting|Insteon and Z-wave devices|Schlage locks|Wink|Canary|Ring
HTML code is On
SimpleHomeNet Plugin Version 1.0.2.0 Beta hurry4it SimpleHomeNet Plug-in 17 September 9th, 2013 10:03 AM
SimpleHomeNet Plugin Version 1.0.1.1 Beta hurry4it SimpleHomeNet Plug-in 21 September 9th, 2013 10:02 AM
SimpleHomeNet Plugin Version 1.0.1.0 Beta hurry4it SimpleHomeNet Plug-in 21 March 23rd, 2013 05:41 PM
Instructions for using the SimpleHomeNet Plugin hurry4it SimpleHomeNet Plug-in 1 March 25th, 2012 06:39 PM
SimpleHomeNet Plugin heatvent HS2 / HSPRO 0 March 21st, 2008 10:54 PM
