Send ir from script in HS3
    Has the command for sending infrared signals in a script been removed in HS3?
    In HS2 I for instance used the code hs.SendIR("Device","Command") to send ir commands thru my GC 100-12 unit with the Global Cache plug-in. I am not able to find similar functions in HS3.
    The IR interface in HS3 has gone completely, as has the X10 one. It is now up to individual plugins to handle scripting calls using hs.pluginfunction. I've downloaded the GC plugin and cannot see that it is mentioned in the help file what function you actually need to call or if indeed this has been enabled. It is not going to be as simple as the previous script command but you might just be able to get away with it in a single line of code.
    A workaround if you are desperate is to have one IR event per IR command and trigger those instead.
    You might want to put in a bugzilla report asking for the documentation to be updated or that feature to be explained.
      I'll put a SendIR into the plugin when I put out a new one..., that should be shortly as I'm starting debugging on that plugin.
      The command for it will read (hs.PluginFunction("Global Cache","",SendIR,{address, data})
      The address is the IP given to the device you wish to send to.
      The data is the command string you want to send to the device.
      This will be a straight pass through to the Global Cache device.
      Wade
      "I know nothing... nothing!"
        Great, thanks.
        I updated to version 5.0.0.6, but I guess the command is not included yet, cause I can't get it to work.
        Have you added commands for sending serial data straight pass through the GC device also?
          What is the status on this matter? Will the global cache plugin support sending ir from scripts soon?
            What is the "SendIR" function name? Has that been added?
            I'm wondering the same thing... Events take too long to trigger IR commands. It would be much faster to either script them or be able to send single script commands via HSTouch buttons.
            I have not yet decided to purchase the Global Cache Plugin. If I can't script commands to it, I will probably look for another solution.
              I would just suggest to get Ultra's GCIR plugin and be done with it.
                How hard is it to script for? I am not well-versed in vb.net, but can program in old fashioned vb all-day-long.
                  Any news on the SendIR script on the Global Cache plug-in ?
                  I try to call it by script , but it have error :
                  Global Cache Error Method SendIR does not exist in this plugin.
                    Are you using HS2 or HS3?
                    This should work.
                    hs.PluginFunction("Global Cache","","SendIR",{"ipaddress", "code"})
                      HS3... And I too get "Global Cache Error Method SendIR does not exist in this plugin."
                        Post your line and let me see if I can see if there may be an issue.
                          This should work.
                          I am using
                          HS3 Pro Edition 3.0.0.96 (Windows)
                          Global Cache Plugin 5.0.0.7
                          For the code , is that mean the IR Code that capture by iLearner in GC format ?
                          Something like this :
                          sendir,1:1,1,38000,1,1,296,171,20,20,20,20,20,20,20,20,20,20 ,19,27,19,27,14,3818
                          But how to specific the Zone on iTach ? (I am using WF2IR , 3 zone at the back)
                            Now I get a different error...
                            Error Running script, script run or compile error in file: C:/Program Files (x86)/HomeSeer HS3/scripts/Test GC Plugin.txt1032:Invalid character in line 5 More info: Invalid character
                            Here's the line... (regular VB script)
                            hs.PluginFunction("Global Cache","","SendIR",{"192.168.0.220", "TV Power"})
                              See the screen capture.
                              Here is the script file :
                              Sub Main(parms as object)
                              hs.PluginFunction("Global Cache","","SendIR",{"172.16.0.169", "sendir,1:1,1,38000,1,1,296,171,20,20,20,20,20,20,20,20,20,2 0,19,27,19,27,14,3818"})
                              End Sub
