HomeSeer SmartHome Skill (Alexa Version 3 API)
    #61
    Originally posted by rmasonjr View Post
    Travis - I'll keep an eye on this thread to see if I need to modify device creation to support.
    Thanks Rob!!!
      #62
      Will this new HS3 SmartHome skill allow HS3 to trigger a routine or scene that is already configured in Alexa?
      Steve Q
        #63
        Looks like Thermostat and Lock commands are not working in API 3 either for me. Thermostat Devices (Omni Plugin) and Locks (Z-Wave) do not show up via the discovery scan.
        UPDATE: Not sure if HS is messing with things right now to fix this stuff but lights are no longer being discovered and discovery is taking way too long and doesn't appear to be adding devices at all.
        -Travis
          #64
          Does anyone have a complete list of V3 utterances? I cant find a comprehensive list from amazon.
          HS4Pro on a Raspberry Pi4
          HSTouch Clients: 1 Android
            #65
            Dimming is working with my test setup, as are the locks and thermostats I have.
            If you send me your license Travis, I'll take a look at what might be the cause of your issues and try to get them sorted.
            wade@homeseer.com
            Wade
            "I know nothing... nothing!"
              #66
              wade@homeseer.com
              Hi Wade, sent you a PM with the info. Also, I just deleted all of my devices that were working on API 3 last night but no HS devices discover anymore.
              -Travis
                #67
                It sounds like most people are able to discover at least some devices in v 3. I still am not able to get v3 to discover devices. v2 when enabled has no problem finding my devices.
                  #68
                  This is my exact situation. v2=good, v3=no joy
                    #69
                    The only way I got my devices discovered was to update HS to the Beta. I still can't figured out how to trigger events yet. Hope someone could shed some light.
                    Hector
                    Win.2003 OS, HS3
                    MyTrigger,ACRF2,W800,Zwave
                    AP800,Honeywell Stat
                      #70
                      Glad I am not alone - sorry but that is a good thing. I thought I was the last not able to update.
                      I am on beta 402.
                        #71
                        Thank you sir for your explanation, that did work. Do you know by any chance how are events triggered?
                        Ok figured it out. You type a command in "voice command" then mark with check mark "set as voice command" in the option section. Then discover events under scenes.
                        Hector
                        Win.2003 OS, HS3
                          #72
                          I am on Beta .404 and Wade gave me a tip regarding my Thermostat. I needed the Root Device to be selected for Voice, not the independent Fan Mode, Cooling Setpoint, Heating Setpoint and Mode Devices. I removed the Voice tick as well as the Voice Command entries for those devices and added the tick and command name "Thermostat" to my Thermostat Root Device and things are starting to work there.
                          I cannot seem to get the "Fan Mode" to change from Auto to On or vice-versa though.
                          Ironically, Lock control doesn't appear to be the same. Setting up the Root Device for my Z-Wave locks did not have the same effect as the Thermostat.
                          -Travis
                            #73
                            I'm on .402 as well.
                            I am on beta 402.
                              #74
                              Good migration here. I'm on 3.0.0.398. Disabled v2, removed the existing devices in the alexa app, then enabled v3 and did a discover. I did everything from echo.amazon.com except deleting the devices. The website would error out on the forget, therefore used the app to delete each device.
                              Devices and Events with the "Voice Command" option selected were discovered.
                              Great Job.
                                #75
                                Hey Rob,
                                You should be good on your side. I figured out part of the issue. I have some special values I add to my devices to determine if they have been dimmed via automation vs at the switch that appear to confuse v3 due to multiple dim assignments. I asked Wade to look into this. If I remove those values, the lights dim as expected but my event logic breaks due to them being removed.
                                -Travis
