How to handle N-way switches...
    How should I handle multiple dimmers for the same light? Do I need two different HS devices? I noticed if I try to change the "virtual" dimmer (the one not attached directly to the load) via HS the LED ramps up and down, but the light stays off.
    With Insteon all groups are local. You have two lights that control each other, but there is no association between them outside of themselves. It is not an N-Way in any real sense.
    There will be an option in the plug-in to control all associated linked units when controlling a master unit, or you can make a new group/scene with HomeSeer that duplicates the linkage between the switches and control the group that way.
    Jon
    Jon Ort
    JonOrt@The--Orts.com
      I assume you are using Insteon or ICON dimmers? If so, did you link the switches? I have a couple of three-way scenarios with ICON dimmers and you have to "link" the additional switches in order to control the load. You can get the detailed instructions from here: https://www.smarthome.com/manuals/2876db.pdf
      Scott
        I think he was asking about HomeSeer control, not local control.
        Jon
        Scott
        Jon Ort
          Oh. I just named my "virtual" devices "no load" so that I would not confuse them with the switch that controlled the load. I never use the HS devices labeled "no load", but I'll try it when I get home.
          Scott
