What am i doing wrong? (Error compiling)
    Hi
    When I try to compile the HomeseerBoard1.ino file, I get the following errors:
    Any idea what I'm doing wrong?
    Arduino: 1.5.8 (Windows 7), Board: "Arduino Duemilanove or Diecimila, ATmega328"
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\Et hernet.cpp: In member function 'void EthernetClass::begin(uint8_t*, IPAddress, IPAddress, IPAddress, IPAddress)':
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\Et hernet.cpp:65:39: error: no matching function for call to 'W5100Class::setIPAddress(IPAddress::<anonymous union>&)'
    W5100.setIPAddress(local_ip._address);
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\Et hernet.cpp:65:39: note: candidate is:
    In file included from C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\Et hernet.cpp:1:0:
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\ut ility/w5100.h:392:6: note: void W5100Class::setIPAddress(uint8_t*)
    void W5100Class::setIPAddress(uint8_t *_addr) {
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\ut ility/w5100.h:392:6: note: no known conversion for argument 1 from 'IPAddress::<anonymous union>' to 'uint8_t* {aka unsigned char*}'
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\Et hernet.cpp:66:38: error: no matching function for call to 'W5100Class::setGatewayIp(IPAddress::<anonymous union>&)'
    W5100.setGatewayIp(gateway._address);
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\Et hernet.cpp:66:38: note: candidate is:
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\ut ility/w5100.h:368:6: note: void W5100Class::setGatewayIp(uint8_t*)
    void W5100Class::setGatewayIp(uint8_t *_addr) {
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\ut ility/w5100.h:368:6: note: no known conversion for argument 1 from 'IPAddress::<anonymous union>' to 'uint8_t* {aka unsigned char*}'
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\Et hernet.cpp:67:38: error: no matching function for call to 'W5100Class::setSubnetMask(IPAddress::<anonymous union>&)'
    W5100.setSubnetMask(subnet._address);
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\Et hernet.cpp:67:38: note: candidate is:
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\ut ility/w5100.h:376:6: note: void W5100Class::setSubnetMask(uint8_t*)
    void W5100Class::setSubnetMask(uint8_t *_addr) {
    C:\Users\mark.REEFIE\Documents\Arduino\libraries\Ethernet\ut ility/w5100.h:376:6: note: no known conversion for argument 1 from 'IPAddress::<anonymous union>' to 'uint8_t* {aka unsigned char*}'
    Error compiling.
    This report would have more information with
    "Show verbose output during compilation"
    enabled in File > Preferences.
    Did you copy the libraries from the zip on the config page to the arduino libraries folder as described in the manual?
    Greig
    Scripts =
    Various
      Hi Greig
      Yes I did, I think that was the problem. I have since deleted the ethernet folder and using the one that comes with the Arduino environment seems to have fixed the issue although it seems to be disconnecting a lot
        Did you set the ethernet settings in the plugin then download the Sketch for the config page and update the board with it as if you change the Ethernet setup you will have to update the board with the sketch.
        If you still have trouble with the board disconnecting then drop me an email with the sketch you are using and a debug log of you connecting to the board and this may help me find the problem.
        Greig.
        Scripts =
        Various
          Yep, I did that. I have noticed that the pin doesn't change status until a disconnect/reconnect either, I'll get a debug log and the sketch in an email to you
            can you ping the board?
            Greig.
            Scripts =
            Various
              Yes, even when it it disconnected from homeseer
