I think I've made a mess. Perhaps deleted some things where I shouldn't have. How best to remove the Arduino plug in, and start fresh again. I've got some buggery going on and screens to add pins are not there, without starting HS3Pro all over again how can I be sure to remove all the podging I don't know how best to clean out a plugin, to be sure I've got a clean chance
My deletions were in the device utility reference page when a few pins did not seem to delete when I removed them in the plugin, perhaps a refresh was in order, but since then it has not been working with the reliability this plugin has provided for the past 6 months.
I'm finding adding pins is not refreshing screens, in some boards the setup is not showing, and I've tried deleting boards and then restart HS3Pro and there boards are still there.
Should I back up, and re-install HS3 or is there a better solution. I've not played with the file system in HS3 so I have no idea how it is set up. This is my first real problem with HS3 that I think is related to some flipped bit and can't explain the odd behaviour.
