Aeon Labs Aeotec Z-Wave Multi-Sensor 6, Gen5
    #61
    Originally posted by macromark View Post
    1.6
    Sent from my Nexus 4 using Tapatalk
    Mark,
    Is there a minimum version of HS3 or zwave plugin to get full functionality out of these? I have firmware 1.6, HS 3.0.0.187 and zwave plugin 3.0.1.25 and I cannot get the vibration/tamper sensor child device to show up. I have rescanned it several times and I either get 7 of 8 child devices or 7 of 7.
      #62
      I'm wondering about updates as well. Do we need to setup polling to have the current temp/humidity?
      -Mike
        #63
        My new Multisensor6 seems to be reporting a temperate that's about 3 degrees hotter. Their webpage says you can adjust / calibrate the sensor. Is there a way to do this from HS3?
          #64
          Check out the manual from the Z Wave Alliance site. That version has all the settings in a chart starting around page 19. The manual is linked to on this page: http://products.z-wavealliance.org/products/1390
            #65
            Is there any reason I shouldn't set these to send updated information every 5 seconds? Would it clog the network?
              #66
              It will shorten the batter life.
                #67
                The detailed manual for the multisensor6 says it should automatically report sensor values when they change beyond a given threshold; 1.8 degrees for temperature. But, that doesn't seem to be happening with HS3. Anyone have this working?
                -Mike
                  #68
                  I've got it plugged in to a power supply so thats not an issue.
                    #69
                    They're not available yet but yes...
                    When will the recessed mounts be available?
                      #70
                      Has anyone been able to get a UV value out of these? Our release sample is reporting "0".
                        #71
                        nope
                          #72
                          I also just get "0" and has never updated.
                          Greig.
                          Scripts =
                          Various
                            #73
                            Yes, you're flooding the network if you're asking the unit to report every 5 seconds. I would suggest 60 seconds or longer.
                              #74
                              Greig.
                              Just to clarify, we're not inserting a "0" value because no value is being received. The unit is literally reporting a "0" value. We see that in the sniffer trace.
                              On the other hand, the unit is not intended for outside use. So, I'm not sure how valuable the UV sensor is. Know what I mean Vern?
                                #75
                                Greig.
                                Perhaps the UV is really low? Have you tried putting it in direct sunlight outside to see if the value changes?
