Using 2 Kinects only 1 allowed to be used as netcam?
    Hi Spud,
    Love your plugins.
    I have 1 Kinect working perfectly as a netcam, the 2nd Kinect is recognized with no problems, however even if the check box to be 'Use Kinect camera as NetCam' is checked there is no URL generated.
    Is this normal that we can only use 1 Kinect as netcam? or am I missing something?
    Both instances have the same snapshot server port 8078, is this the problem?
    Chris
    you should be able to use both as netcams. Both instances are running locally on the same PC or is one of them a remote instance?
    if both instances run on the same machine, then you have to change the port for one of them
