Updating from Arduino V1.0.0.36 to V1.0.0.131 Notes.
There are many great changes in this upgrade including the following:
Linux compatible with Ethernet connection only
LCD Display can be used
Debounce on the input was fixed
Fixed URL encoding on the config page.
PWM now uses Soft PWM so any pin can be used on the board.
Added Alive pin to board that triggers on board disconnect
Added Advanced Ethernet settings to allow all pins to be used.
Added Advanced comport settings to allow baud to be set
Added one wire resolution
Added one wire error value to devices
Added RGB Colour picker to device management page
Added Lots more logging
Add Pin to user notes.
Fixed international formatting
Fixed HSTouch tracking
Connect and disconnect buttons on the config page now update
Added timer for fault of one wire bus
40 inputs can now be used
Lots and lots of other bug fixes
The biggest changes are that you will need to use Arduino IDE V1.6.8
Add output Blink, flash and toggle which will be the biggest thing you notice as this will create a second device for every output device you have to ad time to the outputs. Blink, flash and toggle buttons will also be added to your output devices. See the Device Control section in the Help File for further details.
If you have any questions on this upgrade please post them here and I will do my best to help you out.
