I wasn't watching what I was doing and accidentally changed access to setup. How do I get back into setup as admin?
Setup Permissions Changed - Can't Access Setup as Admin - Help!
Originally posted by cowinger View PostI put this in the wrong thread.
I have another issue here. I have 2 entries for the same thing as users and there is one for admin + local and the other says normal. I tried deleting the normal one but it keeps coming back.
What do I do to get rid of the second one? thanks
Originally posted by Rupp View PostDelete the users.cfg again.
How do we limit what people can access. Like for a family member to just turn on/off lights or something like that? thanks
Originally posted by Rupp View PostYou need to use your myHomeSeer connection unless you want to get into port forwarding via your router.
So I take it there is no way to limit what is accessible by other users? thanks
My iPad rarely leaves the premises and has been set this way since a time when MyHS was having difficulties.
Originally posted by zwolfpack View PostNot necessarily, if you only want to access it from your local LAN. You can set the server address to the local IP address or the computer name. I have Server1 address set to "hometroller" for example. Then the user name and password should be able to be set to any of the entries defined on the Settings Network tab.
