INSTALLATION / CONFIGURATION
System Requirements:
This plugin is for HS3 or HS3PRO. It works with both Windows and Linux versions.
It supports DirecTV set top box models H21, HR20 and newer.
DirecTV Configuration:
Plugin Installation:
Download and install from the updater, or download package from the Beta Testing thread and follow instructions to install.
To install on Linux
You will probably have to install the System.Xml.Linq mono library.
For instance on Ubuntu:
Plugin Configuration
Start the plugin from the "PLUG-INS > Manage" page and go to the config page "PLUG-INS > DirecTV > Config". Fill in the IP Address and port of your DirecTV set top box.
To install on Linux
sudo apt-get install libmono-system-xml-linq4.0-cil
