Originally posted by Blade
View Post
Cheers Ken
Sub Main(ByVal param As Object) hs.PluginFunction("BLLED", "", "SetMessage", New Object(){1, "A", "Test 1"}) hs.PluginFunction("BLLED", "", "SetMessage", New Object(){1, "B", "Test 2"}) hs.PluginFunction("BLLED", "", "SetMessage", New Object(){1, "C", "Test 3"}) hs.PluginFunction("BLLED", "", "SetSequence", New Object(){1, "ABC"}) End Sub
HSPI_BLLED.exe server=[ip address of your main HS3 machine] instance=[instance name]
HSPI_BLLED.exe server=192.168.1.50 instance=office
hs.PluginFunction("BLLED", "", "SetString", New Object(){1, "1", "80 F"})
hs.PluginFunction("BLLED", "", "SetMessage", New Object(){1, "A", "Temp is {callstring=1}"})
