HStouch screen values won't refresh
    I've created a screen in designer with the value 'Elektra huidig verbruik'
    On the HS webserver I can see the value's change when more/less energy is used only the HSTouch screen value stays the same.
    When I close the application on my iPhone and reopen it then it refeshes the value.
    Is this a setting I missed?
    No, it should just work. Do other devices update correctly?
    Perhaps better to post this question in the HStouch forums, as it seems like a HStouch issue.
    stefxx
      Wow you're fast :P
      Yes they do.
      Ok will do.
        I don't own an iPhone (or any other Apple device) but it works on Windows and Android... so not sure how I can be of more help, sorry.
        stefxx
          No worries. I have an android tablet to.
          I'll check if this does work.
            I've just tested this on Windows, Android and iPhone and the weird thing is that other vallues get updated on all platforms (Verbruik netwerk totaal / Verbruik netwerk vandaag) Only the 'Elektra huidig verbruik' doesn't refresh on Android and iPhone but it does refresh on the Windows client.
            Do you also use the 'Elektra huidig verbruik' parameter on an Android device?
              I
              I have exactly the same issue. Does anyone know how we can solve this issue?
              John
                Originally posted by John245 View Post
                I
                John
                A deep dive into this showed that "Elektra verbruik laag" is also not updated on the iOS client.
                Currenltly I can not test all patrameters as in the weekend only the low tariff is applcable.
                John
                  John
                  "Elektra verbruik hoog" is also not updated.
                  On HS Mobile it is working correctly, so it should be an iOS client issue.
                  John
                    This issue is fixed in v 3.58ß of the iOS app.
                    Excellent support of the HomeSeer team.
                    John
