where are the notes regarding new versions posted
    just looking for the changes between versions
    Mark
    HS3 Pro 4.2.19.5
    Inside the plugin under about there should be a hyperlink for Revision History. As far as seeing it before you install though I'm not sure. He used to have it on his web page when it was all hosted there, but I don't know that it is there now.
    Last few versions:
    Build Number Change Descriptions
    2.0.127.0
    Attempt to fix an issue where all sensors get deleted from config file.
    2.0.126.0
    Removed status only on all sensors owned by the plug-in.
    2.0.125.0
    Added debug logging.
    2.0.124.0
    2.0.123.0
    Attempt to fix an issue with dimming devices.
    2.0.122.0
    2.0.121.0
    2.0.120.0
    Cleaned up some code.
    2.0.119.0
    BLRadar will now clear properties on a device that is removed from the plug-in.
    Jeff
