Originally posted by jeubanks
View Post
Coming Soon: Vera Plugin
Originally posted by Tillsy View PostI would suggest it's just basic info such as ID, device type, etc but I've reached out to Tony (the developer) and will let you know what he confirms.
This PI will be for similar use of pulling Vera devices into HS3 for use within HS3.
I'm really looking for a Plug In that allows use of Vera Apps such as PLEG to control HS.
Now that is a Plug In that I would gladly pay for as there are so many Vera Applications that are all free and are all sooooo useful.
If this Plug In can do this (I'm not interested in using Vera for the radio, but understand that there are many who do) then you will have a priceless Plug In.
Circle me in as a Alpha tester.
Originally posted by Black Cat View PostI'm really looking for a Plug In that allows use of Vera Apps such as PLEG to control HS.
That is possible but Vera would fall over and burn trying to handle the load. For a very small number of devices it might work.
I would still like to rekindle the PLEG vs Events and see if EasyTrigger could get involved to bridge the gap.
None are currently bridged, but I am thinking about changing that. I also run one US and one UK ZWave system but that might cease soon.
One is still on UI5 and the other two current. One UI7 unit has a plugin that loads a ton of lighting devices but eats memory and cpu so I keep that separate and then my other is the main controller.
Pulling them all into HS is kinda attractive and so I just wondered if you might be able to support multiple Veras ?
Originally posted by CouchPotatoe View PostNone are currently bridged, but I am thinking about changing that. I also run one US and one UK ZWave system but that might cease soon.
Multiple Vera's was on my list and now it's moved to the TOP of the list. I'm literally starting to work on that now.
Probably a long stretch, but is there any way this could work over different networks?
I have a second Vera at my holiday home (vacation home to you folk) that I unfortunately purchased right before my first Vera revealed it true evil colours (colors ).
If I migrate my primary home to HomeSeer would be nice to also merge into it the devices at my secondary home.
Originally posted by Tillsy View PostProbably a long stretch, but is there any way this could work over different networks?
