Anyone know what the newest update changes? The release notes link in the updater doesn't point to release notes, just back to the plugins page.
Version 3.0.2.1 - What's the change?
I need to update the sticky post. You can find a link to the README from the sticky post that points to http://www.kazteel.com/HomeSeer3/Nap...NI_README.html
The note from the README for 3.0.2.1 reads:
Version 3.0.2.1 (11/17/2017)
Do not update timestamp on HS3 device for every area status update from the keypad bus
Also note, HST is changing how plugin authors provide changes to the updater and they are working on at least one bug related to the "Release Info" link isn't correctly showing. That might have helped you track down this link to the README but now you have it. Hope this helps.
NathanHS 3.0.0.435 (PRO)
Hardware: Napco GEM-P9600 | VenstarT1800 w/Insteon 2441V adapter | Insteon PLM
Plugins HS3: Napco Gemini (mine) | Insteon Thermostat (mine) | Insteon Plug-in (mnsandler) | HSTouch Server (HST)
Platform: Windows 10 Pro 64bit, core2 duo 2.0Ghz, 4GB memory
