Airplay Speak - HS3 Beta testing
    Attached is the HS3 Beta version (= most recent version) of the Airplay Speak plugin.
    Please read the User Guide before installing.
    Installation:
    • download the zip attached to this post and save it in the HS3 application folder /Updates3/Zips
    • download the file named updater_override.txt attached to this post and save it in the HS3 application folder.
    • go to the "PLUG-INS > Manage" page and click the "Update Listing" button, then click "Additional interfaces > Test Plugin" and check the Airplay Speak line.
    • click the "Download and Install" button
    • enable the plugin from the "PLUG-INS > Manage" page
    • delete updater_override.txt from your HS3 application folder
    Please report any bug. Thanks!
    Changes to v3.0.0.13
    - Ignore SETUP response without timing port.
    Changes to v3.0.0.12
    - Fixed avahi dll installation on Linux
    Changes to v3.0.0.11
    - Fixed playing file on Linux
    Changes to v3.0.0.10
    - Fixed disconnection problems
    - Added "Log to file" option
    - Revamped config page
    Changes to v3.0.0.9
    - Support for AppleTV 4th gen
    Changes to v3.0.0.7
    - Changes for Linux build
    Changes to v3.0.0.5:
    - Possibility to use SAPI instead of System.Speech API in order to have SAPI xml tags working.
    Changes to v3.0.0.4:
    - Fixed DMO resample of wave files
    Changes to v3.0.0.3:
    - Fixed a bug affecting only old password protected AirPort Express (firmware <= 6.3)
    Error?
    Hi Spud, I installed as recommended but having problems....
    Note HS updated itself to the new 3.0.0.1 version when I rebooted - not sure if that is the problem or if I need to do something else. Error screen shot attached.
      still works for me after HS updated to 3.0.0.1
      Could you try to restart HS (and enable Airplay Speak PI if it's not) and then send me the full logs (from View / Log)
      thanks
        Also make sure the Apple Bonjour service is installed and running on your HS3 machine.
        If it isn't, you can download it from the following links:
        64bits version: https://www.dropbox.com/s/a0lhdxpbd19go4i/Bonjour64.msi
        32bits version: https://www.dropbox.com/s/dkoi00zvlhxx2cn/Bonjour.msi
          Tried turning it on and off and reinstalled the plug-in
          Tried turning it on and off and uninstalling and reinstalling the airplay plugin - no joy - still the same error.
          See below for section of Log w/ Airplay error information.
          I also tried shutting down my HS2 machine thinking they had some type of contention problem but that did not help. Not sure what else to try/do.
            Not sure what's wrong. I have to check with HS guys what does this error mean and when it can happen.
            I can't reproduce this myself.
            Anyone else experiencing the same problem?
              Some additional info
              I still have not solved this, I was thinking my Symantec Anti-Virus SW (which is managing my firewall) was blocking the Bonjour service or it was not running properly.
              I checked the windows service and it looked OK but to be safe I created some firewall rules to allow the Bonjour TCP/UDP traffic to pass. I even made a few application rules for HS3 and the HSAirplay.exe plugin - no joy
              Turned off the firewall, no joy - I even installed iTunes to verify no issues with Bonjour. I can stream music to my Airplay speakers from the HS3 PC so I'm assuming this is not a Bonjour issue - totally out of ideas... Sigh
                will install tonite when I get home and see what it does for me
                the may 31st post is a reported issue with other plug-ins ( fyi )
                may be all connected
                see below for Global Cache..
                Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
                  here ya go.. updated to HS3 3.0.0.2
                  problem still exists... I am almost sure it is them as it happens with more than your program..
                  Geary
                    and then I tried the global cache.. and your error went away
                      thanks a lot for the tests.
                      so a workaround is to start another paid plugin or to restart HS3?
                        not sure.. the problem did not come back... my guess as I saw in other plug-in posts, was just to restart HS and enable the plug-in again
                          spoke too soon
                          set up an event to track front door
                          got following error
                            got following error
                            Could you try to set the debug setting to Yes, re run the event and send me the full log.
                              Message/Source
                              6:01:47.333 PM AirplaySpeak Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
                              6:01:47.333 PM AirplaySpeak Connection to Living Room (192.168.1.70:5000) failed: Request failed, read error
                              6:01:45.451 PM AirplaySpeak RECORD rtsp://192.168.1.85/1129259477 RTSP/1.0CSeq: 3Session: 80B838D0Range: npt=0-RTP-Info: seq=1581;rtptime=17301User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 62CC856E7C71C7A6
                              6:01:45.451 PM AirplaySpeak Audio-Latency, 11025
                              6:01:45.441 PM AirplaySpeak Transport, RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=6001;timing_port=6002;server_port =6000
                              6:01:45.431 PM AirplaySpeak Audio-Jack-Status, connected; type=analog
                              6:01:45.421 PM AirplaySpeak Session, 80B838D0
                              6:01:45.421 PM AirplaySpeak CSeq, 2
                              6:01:45.332 PM AirplaySpeak SETUP rtsp://192.168.1.85/1129259477 RTSP/1.0CSeq: 2Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=60474;timing_port=60473User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 62CC856E7C71C7A6
                              6:01:45.322 PM AirplaySpeak CSeq, 1
                              6:01:45.312 PM AirplaySpeak Audio-Jack-Status, connected; type=analog
                              6:01:45.271 PM AirplaySpeak ANNOUNCE rtsp://192.168.1.85/1129259477 RTSP/1.0CSeq: 1Content-Type: application/sdpContent-Length: 182User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 62CC856E7C71C7A6v=0o=iTunes 1129259477 0 IN IP4 192.168.1.85s=iTunesc=IN IP4 192.168.1.70t=0 0m=audio 0 RTP/AVP 96a=rtpmap:96 AppleLosslessa=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
                              6:01:45.141 PM AirplaySpeak Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
                              6:01:45.131 PM AirplaySpeak Connection to Bedroom (192.168.1.65:5000) failed: Request failed, read error
                              6:01:42.774 PM AirplaySpeak RECORD rtsp://192.168.1.85/3051709857 RTSP/1.0CSeq: 3Session: 809F7A20Range: npt=0-RTP-Info: seq=6744;rtptime=38452User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 10C2ADF771F8B91C
                              6:01:42.774 PM AirplaySpeak Audio-Latency, 11025
                              6:01:42.774 PM AirplaySpeak Transport, RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=6001;timing_port=6002;server_port =6000
                              6:01:42.774 PM AirplaySpeak Audio-Jack-Status, connected; type=digital
                              6:01:42.774 PM AirplaySpeak Session, 809F7A20
                              6:01:42.774 PM AirplaySpeak CSeq, 2
                              6:01:42.773 PM AirplaySpeak SETUP rtsp://192.168.1.85/3051709857 RTSP/1.0CSeq: 2Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=60471;timing_port=60470User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 10C2ADF771F8B91C
                              6:01:42.773 PM AirplaySpeak CSeq, 1
                              6:01:42.773 PM AirplaySpeak Audio-Jack-Status, connected; type=digital
                              6:01:42.773 PM AirplaySpeak ANNOUNCE rtsp://192.168.1.85/3051709857 RTSP/1.0CSeq: 1Content-Type: application/sdpContent-Length: 182User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 10C2ADF771F8B91Cv=0o=iTunes 3051709857 0 IN IP4 192.168.1.85s=iTunesc=IN IP4 192.168.1.65t=0 0m=audio 0 RTP/AVP 96a=rtpmap:96 AppleLosslessa=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
                              6:01:42.670 PM TTS Speak: ():Front Door is open
