When you load BLRadar in HS3 for the first time, you can convert your HS2 sensors and UDMC code to HS3.
In the BLRadar for HS3, under the Tools menu there is an option to convert the sensor data. You will be prompted for the location of your HS2 hspi_BLRadar.ini and UDMC xml files
The plugin will then convert them to HS3 and create all sensor devices in HS3 for you.
