Good news, they have released version 1.1 of the Nest API, and the humidity% is now available, so I'm going to add a new device for this value.
Nest Plug-in - Beta Testing
And... I take that back.
The 'HVAC Status' will switch from heating or cooling to idle long before the fan is turned off. I still can't use this for what I need.
Maybe there is no way to do this other than the mechanical way I was with the ocelot.
I simply need to know when the fan is mechanically moving or stationary.
so, to maximize chances to see both features in a future version of the API, add your upvote and comment to this feature suggestion: https://community.nest.com/ideas/4101
I simply need to know when the fan is mechanically moving or stationary.cheeryfool
Originally posted by mulderonline View PostHi,
I m under windows 7 32b
Framework 4.50709
anyway, could you try to install or re-install .NET 4.5: http://www.microsoft.com/fr-ca/downl....aspx?id=40779
jscottneal
Plugin Nothing Happens When Hitting Done
I have the latest beta of the Nest plug in and I am using the Linux beta of HS3. When I try to configure and link the plug in to the Nest, I go to the Nest page, get the activation pin, input into the form on the plug in configuration. When I hit done, nothing happens and it just hangs. Have tried multiple times and have deleted the Works With Nest entries for this and tried again. I saw someone else with this problem and they alluded to the fact that it was a firewall issue, but nothing else.
I have this as a log entry and any help is appreciated.
Scott
DEBUG System.TypeInitializationException: An exception was thrown by the type initializer for Newtonsoft.Json.Utilities.ConvertUtils ---> System.IO.FileNotFoundException: Could not load file or assembly 'System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. File name: 'System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' --- End of inner exception stack trace --- at Newtonsoft.Json.Serialization.DefaultContractResolver.IsJson PrimitiveType (System.Type t) [0x00000] in :0 at Newtonsoft.Json.Serialization.DefaultContractResolver.Create Contract (System.Type objectType) [0x00000] in :0 at Newtonsoft.Json.Serialization.DefaultContractResolver.Resolv eContract (System.Type type) [0x00000] in :0 at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.G etContractSafe (System.Type type) [0x00000] in :0 at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.D eserialize (Newtonsoft.Json.JsonReader reader, System.Type objectType, Boolean checkAdditionalContent) [0x00000] in :0 at Newtonsoft.Json.JsonSerializer.DeserializeInternal (Newtonsoft.Json.JsonReader reader, System.Type objectType) [0x00000] in :0 at Newtonsoft.Json.JsonSerializer.Deserialize (Newtonsoft.Json.JsonReader reader, System.Type objectType) [0x00000] in :0 at Newtonsoft.Json.JsonConvert.DeserializeObject (System.String value, System.Type type, Newtonsoft.Json.JsonSerializerSettings settings) [0x00000] in :0 at Newtonsoft.Json.JsonConvert.DeserializeObject[AccessTokenResponse] (System.String value, Newtonsoft.Json.JsonSerializerSettings settings) [0x00000] in :0 at Newtonsoft.Json.JsonConvert.DeserializeObject[AccessTokenResponse] (System.String value) [0x00000] in :0 at NestSharp.NestClient.GetAccessToken (System.String pin) [0x00000] in :0 at HSPI_Nest.WebConfig.postBackProc (System.String page, System.String data, System.String user, Int32 userRights) [0x00000] in :0
