I have submitted a helpdesk ticket, but wondering if someone else has dealt with this issue before
Unit is setup to use gmail, and successfully sends email. error log reveals failed login attempts . below is the error message
Unable to log into Gmail server: Authenticate as SSL client failed. You might be connecting to non SSL port.:Inner Exception: System.IO.IOException: The authentication or decryption has failed. ---> Mono.Security.Protocol.Tls.TlsException: Invalid certificate received from server. at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertifi cate.LocalValidation (Mono.Security.Protocol.Tls.ClientContext context, AlertDescription description) [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertifi cate.validateCertificates (Mono.Security.X509.X509CertificateCollection certificates) [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertifi cate.ProcessAsTls1 () [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.HandshakeMessage.Proces s () [0x00000] in :0 at (wrapper remoting-invoke-with-check) Mono.Security.Protocol.Tls.Handshake.HandshakeMessage:Proces s () at Mono.Security.Protocol.Tls.ClientRecordProtocol.ProcessHands hakeMessage (Mono.Security.Protocol.Tls.TlsStream handMsg) [0x00000] in :0 at Mono.Security.Protocol.Tls.RecordProtocol.InternalReceiveRec ordCallback (IAsyncResult asyncResult) [0x00000] in :0 --- End of inner exception stack trace --- at Mono.Security.Protocol.Tls.SslStreamBase.AsyncHandshakeCallb ack (IAsyncResult asyncResult) [0x00000] in :0
