Hi
Is it possible to use this interface with the CM11.
I use the interface from Jeff Volt because it uses higher output levels. I am currently using the Homeseer version of the plugin but it does not have the level of devices this plugin has.
I did try to use the plugin but none of the devices activate so I guess it does not support the CM11
Regards
Ken
Regards
Ken
