I have written the attached script which appears to function. It is controlling the Central Heating and two hot water tanks in my house in conjunction with Temp05 sensors.
However, I get the error message above so something must be wrong ?
There are still some notes in the script as I intend to expand this for my new house which is under construction now, this will have 9 heating zones.
any ideas ?
Nigel
' 24/02/02 CH and HW Control script
' This script is to be used to control my CH Zone Valve and 2 HW Zone valves in conjunction
' with a midon Temp05 and Relay05
Dim water1
Dim water2
Dim LivingRoom
Dim ReqTemp
' Temporary script to set thermometer levels
'hs.SetDeviceValue "H1",46
'hs.SetDeviceValue "H2",46
'hs.SetDeviceValue "H3",19
'hs.SetDeviceValue "H10",21
' Collect values from virtual devices
water1 = hs.DeviceValue("r3")
water2 = hs.DeviceValue("r7")
LivingRoom = hs.DeviceValue("r6")
ReqTemp = hs.DeviceValue("r64")
If LivingRoom < ReqTemp Then
' hs.speak "Heat On"
hs.SetDeviceStatus "v2",2
hs.SendToComPort 1,"RLY 6 on"
hs.waitsecs 1
Call HW1
Else
' hs.speak "Heat Off"
hs.SetDeviceStatus "v2",3
hs.SendToComPort 1,"RLY 6 off"
hs.waitsecs 1
Call HW1
End If
' Temporary speech stuff !!!!!!!!!!!
'hs.speak "Hot Water 1 temperature is"
'hs.speak water1
'hs.speak "Hot Water 2 temperature is"
'hs.speak water2
'hs.speak "Living Room Temperature is"
'hs.speak LivingRoom
' Begin Main Subroutine
' There can be as much code between here and
' the subroutines as you want. CALLing the
' subroutine will jump dirrectly to the
' beginning line of that Sub.
' End of the Main Subroutine
'Subroutines HW1 and HW2
Sub HW1
If water1 < 38 Then
' hs.speak "Hot Water 1 On"
hs.SetDeviceStatus "v10",2
hs.SendToComPort 1,"RLY 7 on"
' hs.speak "Hot Water 2 off"
hs.waitsecs 1
hs.SetDeviceStatus "v7",3
hs.SendToComPort 1,"RLY 8 off"
hs.waitsecs 1
Else
' hs.speak "Hot water 1 Off"
hs.SetDeviceStatus "v10",3
hs.SendToComPort 1,"RLY 7 off"
hs.waitsecs 1
Call HW2
End If
End Sub
Sub HW2
If water2 < 38 Then
' hs.speak "Hot Water 2 On"
hs.SetDeviceStatus "v7",2
hs.SendToComPort 1,"RLY 8 on"
hs.waitsecs 1
Else
' hs.speak "Hot water 2 Off"
hs.waitsecs 1
End If
End Sub
'hs.speak "End of script"
any ideas ?
Nigel
Dim water1
Dim water2
Dim LivingRoom
Dim ReqTemp
hs.waitsecs 1
Call HW1
Else
hs.waitsecs 1
Call HW1
End If
'hs.speak water1
'hs.speak water2
Sub HW1
If water1 < 38 Then
hs.waitsecs 1
hs.waitsecs 1
Else
hs.waitsecs 1
Call HW2
End If
End Sub
Sub HW2
If water2 < 38 Then
hs.waitsecs 1
Else
hs.waitsecs 1
End If
End Sub
