Jim S had a similiar problem that was traced to mixed case in the Interface property of the devices. I made an attempt to correct this with the latest which contains some debug on clock sync just a few posts up. I also posted a utility in this thread to manage the Interface property. This will at least give you an easy way to observe what you have.
ADIOcelot Plugin
sbessel
Originally posted by Michael McSharryJim S had a similiar problem that was traced to mixed case in the Interface property of the devices. I made an attempt to correct this with the latest which contains some debug on clock sync just a few posts up. I also posted a utility in this thread to manage the Interface property. This will at least give you an easy way to observe what you have.
sbessel
It looks like I have the same problem as jsteed
here is a device hanging off one of my Sec16's It works properly in 1.7.0 anything higher and it does not show up. All the rest of my Ocelot devices are like this one, interface wise.
So what was the fix? I can't see manually editing my .xml file, that seems like a huge risk...
PHP Code:<z:row record_type='1' can_dim='False' dc='3' dev_type_string='GarageDoor' hc='$' interface='' iomisc='2!11!2!1'
iotype='0' location='House' misc='16' name='Garage Closed (t)' ref='42832' sldim='0' status='17' status_support='False'
ui_action='' buttons='' values='' zwave_nodeid='0' zwave_nodetype='0' zwave_pollrate='0' CS_Status='0' IS_Label=''
IS_Ircommand='' IS_Value='0' IS_Image='' IS_Row='' IS_Column='' delete='False' dtmf='' eprom_address='' ev_abs_time='0'
ev_app_path='' ev_date='' ev_days='0' ev_dimpercent='0' dim_to='False' ev_func='0' ev_hc='' ev_mail_message=''
ev_mail_subj='' ev_mail_to='' ev_offset='' ev_offset_before='False' ev_time='' ev_trig_dc='' ev_trig_func='0'
ev_trig_hc='' ev_wav_path='' events='' group='' handled='0' ir='' irmatch='0' mail_attach_path='' evmisc='0'
misc_actions='' evmisc2='0' evname='' phone_actions='' phone_event='0' phone_line='0' pi_trig_name='' pi_trigger=''
popfrom='' rec_mins='0' rec_secs='0' relay='' scripts='' sec_action='' sec_trigger='' security_offset='0' speak_after_script=''
speak_before_script='' speak_device='0' speech='' vcmd='' pi_actions='' cd_condition='0' cd_ctype='0' cd_dev_ref='0'
cd_time='' cd_orindex='0' cd_plugin='' dev_devid='0' dev_dim_percent='0' dev_dimto='0' dev_eprom_address='0'
dev_func='0' dev_new_string='' dev_secs_delay='0' setpoint_action='0' tv_daytime='0' tv_daytimerdate='1899-12-30T00:00:00'
tv_moddev='' tv_modhouse='' tv_nolimit='False' tv_passdev1='' tv_passdev2='' tv_passdev3='' tv_passdev4='' tv_passhouse=''
tv_status='0' tv_timetype='0' tv_totaltime='0' tv_useddaytime='0' tv_usedtime='0' tv_username='' retrigger_delay='0'
graphics=''/>
yes, that's what mine looked like. I edited the file manually with an xml editor, XML Marker which made it fairly painless. Sort by housecode and then cut/paste. You'll need to do it with HS shutdown. Just make sure that you keep a backup (or two).
The utility that Michael mentioned, ManageInterface, was included in the AdiOcelot194.zip.
jim
Michael,
When you send the packet to the ocelot are you sending 1-7 for the weekday or 0-6?
I want to experiment a little more with this but I did get this yesterday during one run. I had just restarted HS with 1.9.6.
1/30/2005 8:41:44 PM~!~Speak~!~HVAC Status Devices Initialized.
1/30/2005 8:43:01 PM~!~ADIOcelot~!~Initiating 59 second wait for start of next minute to set clock
1/30/2005 8:44:00 PM~!~ADIOcelot~!~For Weekday 1, Setting Clock to 200501302044
1/30/2005 8:45:00 PM~!~Event Trigger~!~Recurring Trigger (Temperature Log)
1/30/2005 8:45:09 PM~!~ADIOcelot~!~Initiating 51 second wait for start of next minute to set clock
1/30/2005 8:46:00 PM~!~ADIOcelot~!~Initiating 0 second wait for start of next minute to set clock
1/30/2005 8:46:01 PM~!~ADIOcelot~!~Initiating 59 second wait for start of next minute to set clock
1/30/2005 8:47:00 PM~!~ADIOcelot~!~Initiating 0 second wait for start of next minute to set clock
1/30/2005 8:47:01 PM~!~ADIOcelot~!~Initiating 59 second wait for start of next minute to set clock
1/30/2005 8:48:00 PM~!~ADIOcelot~!~For Weekday 1, Setting Clock to 200501302048
jim
After I posted last night I found a second version of the set clock function (same document as the first version, just two pages farther down). It's mostly the same except for a couple of items. I'll post it tonight when I get home. I noticed with the second one rather than having the leading zeros that it showed those two positions as setting the seconds digits. That should eliminate the need to sync the clock set.
jim
Here's the alternate version (why this is defined twice in the same document I'm not sure). This indicates that the seconds can be set as well.
The other thing that it shows is that it's looking for weekday to be 0-6. That would explain how it's acting on my system. However, it doesn't explain why it's working on Paul's system. (I hate stuff like this- makes my head hurt)
jim
Set CPUXA Real Time Clock
->Send 50 binary bytes: <241> <61> <n2> <n3>…… <n47> <n48> <csum>
<-Receive 3 byte header: <6> <0> <6>
Note: This command loads and starts the CPU-XA Real Time Clock.
n2 = 61; //set RTC
n3 = seconds ones digit 0-9 (23:59:3x)
n4 = seconds tens digit 0-5 (23:59:x4)
n5 = minutes ones digit 0-9 (23:5x:34)
n6 = minutes tens digit 0-6 (23:x9:34)
n7 = hours ones digit 0-3 (2x:59:34)
n8 = hours tens digit 0-2 (x3:59:34)
n9 = day ones digit 0-9 (12/0x/99)
n10 = day tens digit 0-3 (12/x4/99)
n11 = month ones digit 0-9 (1x/04/99)
n12 = month tens digit 0-1 (x2/04/99)
n13 = year ones digit 0-9 (12/04/9x)
n14 = year tens digit 0-9 (12/04/x9)
n15 = day of the week 0-6 (Sunday-Saturday)
csum = the 8 bit sum of 241 + 61 + n2 + n3 + n4…n47 + n48
I added the seconds, made the weekday range 0..6, and changed the sync algorithm to try to set the clock 2 seconds after button push or at 1 AM. Some form of sync/retry is needed to handle the situation where the ocelot is busy at the time the set clock desires to start. Debug still in at point of setting the clock.Last edited by Michael McSharry; February 5, 2005, 05:45 PM.
It's been loaded for about 24 hours now. I set the clock several times yesterday and today. So far I haven't seen anything that I shouldn't. I'll keep an eye on it for a day or two but it appears to be working fine for me now.
As others have said- thank you for the time and effort that you spend making this and other items available for the rest of us.
jim
