Hey Mark, been a long time. Your progress on this plugin is awesome.
I am having some issues and wanted to get your thoughts.
Specs:
HomeSeer version is: 2.3.0.60
Insteon, version: 1.5.3.0
Device Type: SwitchLinc 220V Relay
Firmware Version: 38
Comm Reliability: 95% (71 failed out of 1318 cmds)
Insteon Device ID: 12.DA.61
Device code: ]41
I have been using a SwitchLinc 220V Relay to control my pool pump successfully until about 90 days ago. The scripts turn the pump on at 10:00 PM and then turns it off after a variable number of hours depending on temperature. For the life of me, I can't remember anything that changed around that time but the device has become unreliable. I have not been able to find a cause so for now, I have modified the scripts that at the appropriate time, will try to turn off the pool pump, poll the device, and if its not off, then wait 5 mins and try again for up to 40 times. I also upgraded the plug in version from 1.4.x to 1.5.3.0
a few weeks ago to see if it would make a difference.
Last night, I turned on "Detailed Debugging Log Entries" logging level at 3/31/2011 10:16:05 PM. I have attached a snippet of the log from when the script started attempted to turn off the SwitchLinc 220V Relay at 4/1/2011 3:42:00 AM through when it was finally successful at 4/1/2011 4:09:07 AM (after 6 attempts). I didn't trim anything out so there are of course other data in the snippet.
The one thing I find odd is that it seems some of the detailed Insteon logging disappeared for a while last night.
3/31/2011 10:16:05 PM - Started detailed logging
3/31/2011 11:27:11 PM - ~!~Insteon~!~ messages seemed to have stopped
4/01/2011 03:57:46 AM - They started back up
Is this a problem with my PLM?
Thanks for your help and let me know if you need additional logs, etc. Gre
Specs:
Device code: ]41
