Originally posted by wposner
View Post
Windows Style Live-Tile UI for HomeSeer
Originally posted by olag00 View PostWell I have gotten past the Blank Black screen and it is showing devices but the navigation bar is not showing up...no rooms. On the mobile, the menu bar has a blank drop down.
I just upgraded from 2.7.3-8 to 2.8.3-5. I am losing way too much screen estate at the top of the page under the navbar before the tiles appear. The wasted space has actually increased between these 2 builds (possibly due to the fix for the overlapping navbar?)
Is there anything that can be done to move the tiles to the top of the page, even if it's an edit that I have to apply locally after each build?
Thanks and keep up the good work!
Originally posted by wposner View PostFor all thes builds the only folders you should be replacing at this point at the component and css folder and the index.html file. Do you have a backup from the last build or can somehow roll back and then upgrade without overwriting so much stuff?
Originally posted by JimBob View PostI just upgraded from 2.7.3-8 to 2.8.3-5. I am losing way too much screen estate at the top of the page under the navbar before the tiles appear. The wasted space has actually increased between these 2 builds (possibly due to the fix for the overlapping navbar?)
Originally posted by JimBob View PostCan you give me a pointer where this could be changed? I don't mind having a poke around and quite willing to have my own custom version of a file(s) that I handcraft after each new build. I really want to be able to get my tiles upto the top.
metro.min.css.txt
Try this. Stick it in the css folder and remove the .txt. I have two browsers open --one with a single row of tabs and one with two rows. The tiles are positioned immediately below the nav bar when there are two rows of tiles and in a position that looks about the same as when I first put out the 2.x build.
Looks to be the best compromise.
