Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HomeSeer Amazon Echo Connected Home API
HomeSeer Amazon Echo Connected Home API Discussions related to the Amazon Echo native support for connected home products
Old June 7th, 2016, 12:15 PM
wcross wcross is offline
Echo/Alexa API "On" versus "On Last Level"
First off, I love the Echo/Alexa integration via the API -- fantastic job!
The only "wife acceptance factor" issue I'm having is asking Alexa to turn on a light always goes to full brightness instead of Last Level. And, after turning on full brightness, this now because the new Last Level.
Is there a way to have the "on" request turn on device to Last Level for those devices that support it?
Old June 7th, 2016, 12:44 PM
vasrc's Avatar
vasrc vasrc is offline
Not sure of the overall ramifications, but if I change the Last Level to On instead of On Alternate, I get the behavior you're looking for. It's located in the Status Graphics tab.
YMMV,
Z
Old June 13th, 2016, 11:35 AM
Gallina's Avatar
Gallina Gallina is offline
ALEXA
Lately when Alexa finishes loading devices she says she could not find any smart devices. Devices still load. ?????
Old September 8th, 2017, 11:45 PM
mulu mulu is offline
YMMV,
Z
I was struggling with the same. In my case I had to do just the opposite of what vasrc said, i.e. I had to set "On Last Level" to On.
Before: Value=99; Status=On, Control Use=On
Value=255; Status=On Last Level, Control use=On Alternate
New:Value=99; Status=On, Control Use=On Alternate
This is with Cooper Wiring 9540/9542 devices.
Tags
alexa, api, echo, last level
Relationship between "Web/HSTouch User Settings" and "myhomeseer" remote access acct? diitto MyHS Remote Access Service 1 February 15th, 2016 02:19 PM
Solved: Conversion from string """" to type 'Integer' is not valid. edentel JowiHue Plug-In 24 December 31st, 2015 07:26 AM
Multiple z-troller question: choosing "(automatic)" for "Z-Wave Interface to Use:"? NeverDie Z-Troller™ 3 September 13th, 2013 05:40 AM
Bug - "incoming call" event trigger with group type as "plugin specific" caller DavidG UltraCID HSPI 4 June 2nd, 2011 10:24 AM
What's the best way to implement modes (like "at home", "away", "sleeping" etc.)? Thrag HS2 / HSPRO 4 August 3rd, 2010 01:15 PM
