Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HomeSeer Amazon Echo Connected Home API
HomeSeer Amazon Echo Connected Home API Discussions related to the Amazon Echo native support for connected home products
  #41
Old December 12th, 2016, 06:04 PM
sirmeili sirmeili is offline
Anyone get this to work on Google Home? I tried and the "Home" app couldn't find neither ha-bridge nor my actual Hue Hub.
Edit: The Google Home got unplugged (probably by a kid...LOL). Gonna try with it plugged in.
  #42
Old December 12th, 2016, 06:10 PM
Nope. still didn't work. I unplugged my actual Hue Hub (Because I have no way of knowing which one it picked up) and after clicking pair, it never does anything. Since the lack of a "Link button", I can't press it (though I realize that ha-bridge is supposed to simulate this)
  #43
integlikewhoa integlikewhoa is offline
Yes this works with google home, but it has to be on port 80 for google home.
  #44
Old December 12th, 2016, 06:14 PM
wow..that stinks. I don't think I can do that (I think something else is using port 80 on my server). I guess I will have to see if I can wait until I get a dedicated low power machine for it (not a high priority since the server will remain running anyways).
  #45
Old December 12th, 2016, 06:15 PM
Also you can find alot more info in the this 148 page thread on this bridge.
http://forum.micasaverde.com/index.p...html#msg300665
Post 2186 on page 146.
If you read threw you will see people are using it on google home and tons of people are using it on ECHO. I know you have changed your ports around and its confirmed you can't do that with Google Home. Echo I'm not sure but your problems are probley somewhere related in your setup for some reason or another.
  #46
Old December 12th, 2016, 06:27 PM
I changed the uPnP ports, which seem to still be working (since Google Home can find it). The port 85 was the port given at the beginning of this thread, and while I realize that this was more geared toward the Echo, I was hoping it would work on the Google Home as well. I find it foolish that the uPnP request returns a url for them to verify it, but apparently Google just ignores that part (or the service they use ignores it: hue-adapter.appspot.com).
I will have to check what is using port 80, but at the very least I can hope for another way to do this after the APIs are all opened up (or someone else does). We are stll primarily an Alexa home, but I wanted to switch to Google Home because we are heavily invested in the Google ecosystem.
Still, Ha-bridge is awesome and is opening up a lot of stuff (Especially with the Harmony stuff, which increased the WAF in the bedroom so she can adjust the ceiling fan and lights from the bed )
  #47
Old December 12th, 2016, 06:42 PM
Yeah the OP started off by changing the defaults right off the bat maybe for some other reasons. And that was for linux. Many won't need to do much but double click the java file on the windows server.
  #48
Old December 22nd, 2016, 09:19 AM
trevor-austin trevor-austin is offline
Seer Plus
I've got this working really well except for two areas.
Firstly, whenever I add my nest account, 9 times out of 10 that corrupts the config and all I get is 404 errors whatever I click on, the only way to get it working again is to delete the data directory and start again.
My Harmony correctly adds all the buttons and devices to create and works fine, but on the odd occasion that my nest account doesn't corrupt it, nothing is pre-populated as I believe it should be, ready to generate devices as with the Harmony tab, nor in the Hue device.
Any ideas?
  #49
Old December 30th, 2016, 01:43 AM
csullivan2005 csullivan2005 is offline
hey guys
So I have a windows embedded home troller sel pro
so this is what I did:
I downloaded jdk 1.8 and then downloaded java -jar ha-bridge-3.5.1.jar
I double clicked java -jar ha-bridge-3.5.1.jar after downloading
I opened up harmony remote and it was able to find my virtual Philips hue bridge
now what do I do next to get light devices in homeseer recognized??
thanks
chris
  #50
Old December 30th, 2016, 01:48 AM
thanks
chris
You skipped the step of opening a webpage and opening tbe web ui for this bridge. When you do that you need to setup or add each device you want to control. Then you can go to your harmony remote and add each one as a hue device.
So try a web page on your hometroller and open this webpage
http://localhost:8080
To see if you can get the web ui of the bridge up.
  #51
Old December 30th, 2016, 01:53 AM
hey guys
tried this with my local host and did not bring up anything. just says webpage cannot be displayed.
what should I do next
  #52
Old December 30th, 2016, 01:59 AM
Running the bridge on port 80 (which is default) is always tuff since its a very popular port. You can try your local ip followed my port 80 or 8080 again instead of local port. If that doesnt work your gonna need to either try to force everything closed to get port 80 temporarily open so you can get to the web ui then change the default port to one of your choice.
If you cant do that then you need to run a custom script to force the bridge to startup on a custom port right fron the start. That might be harder for you then the first options.
  #53
Old December 30th, 2016, 02:03 AM
just what to make sure I'm clear. when you say localhost you are referring to my homeseer ip address correct?
  #54
Old December 30th, 2016, 02:07 AM
my homeseer ip followed by:80 led me to a page where on top I see
HA bridge Home. My Echo. Help. About
but then all white space below
  #55
Old December 30th, 2016, 02:13 AM
works with google chrome....again I used port 80. how do I change the port to 8080 later?
I'm going to further dive into manually entering devices tomorrow. how do I go about doing this??
  #56
Old December 30th, 2016, 02:19 AM
also is this setup going to mess up or interfere with my Alexa homeseer plugin?
I using the skill where I can just say Alexa turn on family room light. and it communicates to homeseer.
are you running both instances?
  #57
Old December 30th, 2016, 11:13 AM
SO MY HARMONY REMOTE HAS RECOGNIZED MY LIGHT I MANUALLY CREATED. I INPUTED THE ON, OFF, AND DIM URLS
HOWEVER WHEN I GO TO TEST I GET ERROR SAYING "REQUEST ERROR., PLEASE LOOK IN YOUR HABRIDGE LOG: ERROR {"TYPE".-6,"ADDRESS"."/LIGHTS/1","DESCRIPTION"."SHOULD NOT GET HERE, NO HARMONY CONFIGURED","PARAMETER"."/LIGHTS/1STATE"}
AM I MISSING SOMETHING. I SELECTED DEVICE TYPE AS CUSTOM
MAP TYPE AS HARMONY BUTTON
I PUT IN MY HOMESEER IP(DO I NEED PORT NUMBER AFTER HOMESEER IP?)
I SELECTED GET FOR HTTP VERB
I SLECTED CONTENT TYPE AS APPLCATION/JSON
DO I NEED TO UPDATE ANYTHING IN BRIDGE CONTROL SECTION?
SHOULD UPNP IP address BE MY ROUTER IP?
DO I NED TO UPDATE MY WEB SERVER IP address TO HOMESEER IP?
ANYTHING ELSE?
  #58
Old December 30th, 2016, 11:42 AM
Great that's all you need your in now. You don't need to change to port 8080 or anything else is this is working for you. This port 80 is only for seeing this web UI and nothing else will be effected. If you have no conflicts with this being eon 80 then leave it be and continue on your quest.
If you had to shut down other services on port 80 for this to work or if you just don;t want it on port 80 then you can click "Bridge control" tab then change the "Web Server Port" to one of your choice and that's what you'll need to enter to access this web UI.
Do not change the UPNP response port it is fine and should not match your router.
You can change the web server IP to the same IP as your homeseer computer. if you do you will not be able to access at localhost:80 you will just use the iport of the homeseer server. Nothing should me the same ip or port as your router.
Your question on "Alexa homeseer plugin". No I do not run that plugin so I can't say it will or won't but only that it shouldn't as this is a stand alone thing. You can always go to the web ui and "Bridge Controls" tab and click stop bridge and you have shut it down.
I think that "Alexa homeseer plugin" is if you don;t have a Amazon echo right? I think the one your talking about is to mimic a real echo? I have several echos and use them with this bridge.
You have not setup your device right which is why your getting an error. I would suggest try no dimming first (do an on/off light) and get that down then move to dimming lights.
Map type is left blank.
You do need you port number.
Http Verb should be "GET"
Enter you on and off and maybe dim on some lights.
The rest can be left blank.
So a basic "ON" should look like this using your ip and port and your device nuumber.
http://192.168.1.100:10201/JSON?requ...=349&value=255
and an "off" like this.
http://192.168.1.100:10201/JSON?requ...ef=349&value=0
this will turn device# 349 on and off. 10201 is my post I use to access the web ui of homeseer. yours will be different along the IP probley.
If it was a dimmer switch the on and off will be the same but instead of the dim being blank you would use.
http://192.168.1.100:10201/JSON?request=controldevicebyvalue&ref=349&value=${intensity. percent}
  #59
Old December 30th, 2016, 12:11 PM
thank you very much so far!
so funny thing is only the dim works
I did exactly what you said for the on and off when I go to test and do Test On or Test Off its says request executed:sucess{"/lights/1/state/on".true} however nothing happens to my light
when I test dim it works
can you please make sure the on and off urls you provided are accurate and didn't get messed up when copying and pasting. thanks
  #60
Old December 30th, 2016, 12:17 PM
also you said map type was blank. what about for device type?
How to add devices in homekit bridge? Carlyle Harper Homekit bridge (3P) 1 November 2nd, 2016 07:49 PM
HS3 Serial RS232 Direct Control xxrzdxx HomeSeer General Discussion Area 19 August 14th, 2015 01:09 AM
URL for direct device control jgreeno HS2 / HSPRO 1 February 4th, 2014 09:23 PM
Direct HTTP (Remote Control) DrDoo HSTouch™ 1 September 23rd, 2011 05:45 PM
