Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HomeSeer Amazon Echo Connected Home API
HomeSeer Amazon Echo Connected Home API Discussions related to the Amazon Echo native support for connected home products
  #61
Old December 30th, 2016, 12:24 PM
integlikewhoa integlikewhoa is offline
Devuce type tou can leave blank it will change it for you.
The copy and paste does shorten the url but you should be able to click and save link and paste it to get the full thing. If its not working can you paste a screen shot or make sure your device is on at 255 and off at 0 in that devices advanced tab. If these are some type of rgb lights or special lighting maybe 255 is not on.
  #62
Old December 30th, 2016, 12:49 PM
I have to assume your error is in the http and its a typo as the dime command and the on and off commands are the same except your using a "$" variable. Everything before the value is spelled out the same. Here is a screen shot or to to help you.
  #63
Old December 30th, 2016, 01:54 PM
csullivan2005 csullivan2005 is offline
It's working now! Yes my light switch has a different On value. It is 99
Have you had any issues where sometimes when you press the light button on harmony remote that it doesn't work or is it very reliable and work all the time? I refreshed my hue connection in harmony phone app and seems to work now. Will keep testing.
  #64
Old December 30th, 2016, 02:36 PM
Its very reliable for on and off. Dimming sometimes seems to be an issue. I'm not sure if I just haven't found the trick, but for the most part I use only on a off.
Glad you found the problem is 99 vs. 255. You can always check your swtiches settings and see what the value is for max and enter that for on. off should always be 0 but you can also change that if need be.
Playing with those urls you can run a scene instead of a light or what ever you need.
Enjoy!
  #65
Old December 30th, 2016, 02:40 PM
Yes dimming is the problem. Anyone else out there figured this out for dimming for it to be reliable? Kinda deal breaker for me. I'm prob going to return my elite remote and get the non touchscreen version "the companion". A company called NEEO has a remote if they ever manufacture and deliver will be the next best remote.
  #66
Old December 30th, 2016, 02:42 PM
Well dimming shouldn't be a problem but it probley is for you because your value stops at 99 not 255. So that means we need to adjust your http command for the dimming to reflect this change. This info on how to do this is in the github page. One sec and I'll find that.
  #67
Old December 30th, 2016, 02:45 PM
thanks...can I just go into status graphics and change it? it has 255 set to last level on mine and 99 has On
I have the cooper rf aspire switches
thanks for your help
  #68
Old December 30th, 2016, 02:46 PM
Well I just checked and you should be good to go.
https://github.com/armzilla/amazon-echo-ha-bridge
Almost all the way down the page. You should see.
"Dimming is also supported by using the expression ${intensity.percent} with a value of 0-100 or ${intensity.byte} with a value 0-255, respectively."
Since your using ${intensity.percent} you should be ok.
There is some samples there. The other issue might be with dimming to 99 or 100%. Homeseer might not accept that and want a on command instead. So you'll have to test to see where you issue lies with dimming.
  #69
Old December 30th, 2016, 02:51 PM
I just went into status graphics and set on as 100 and dim from 1-99. Before it was 1-98 and on was 99. Maybe this will work now. Will test it out.
  #70
Old December 30th, 2016, 02:52 PM
That might not workout for you on changing that device to 255, but I can;t really anwser that for sure.
If you do that you could also try that "${intensity.byte}" http instead of the percentage.
A little bit of playing around you should get it.
Also I have only the non touch screen versions on the harmony. And the probley I have with dimming is there is only one plus and minus for the 4 buttons. So my confusion is on how to work the dimming properly with the remote. You need to turn on the light first which is 100% then use the plus and minus to dim. But how long before it times out the plus and minus don;t know which light to dim.
I would assume the touch screen version has no issue with this as you can select the light from the list then dim up or down. Your also not limited to 4 buttons or devices per remote like I am.
I have one remote per room and use them just for that room light, fan, maybe a hallway light for restroom walks for the kids or something.
  #71
Old December 30th, 2016, 07:41 PM
you mean your remote has two light bulbs and two wall switch buttons right?
do you do scenes or anything with the other four color buttons
also if I have 4 lights under hue bridge I assume those count as 4 devices and not 1 with harmony?
im really thinking about getting the remote I think you have which is more than half the price of mine because I have iPads in my rooms as well and really only need to control lights in my tv room and then maybe 2-3 scenes. also harmony remote isnt very good at controlling sonos or thermostats
  #72
Old December 30th, 2016, 08:08 PM
Correct so 4 devices total its able to control
I don't do any scenes myself and the 4 color buttons are not part of the home or programmable options. You can only program the two light and two outlet buttons to home control or this hue decives.
That is correct, unless you make a scene that turns all on and all off at one time. But then you have no separate control of them if you ever want that from the remote.
Mine retails for 149.99 and can be found for 120 ish new or less if refurbished. My father just bought one this weekend at bestbuy for 129.99 after they priced matched an online price from homedepot I found.
Without the screen you will have only some basic control of 4 total devices or scenes. So if you only have 1 light a fan and two scenes your good. Technically you could run 4 scenes as you can make a button to run one when you turn it on and a different scene when you turn it off. So you can squeeze it. You will also not have the name labels on the switches or touch screen like you do now. You'll have to remember which outlet icon does what for on and off. Pretty much you'll know but no one else will. And if you ended up like myself with one in each room that makes it even harder to remember.
  #73
Old December 30th, 2016, 11:48 PM
thanks
I think ill keep mine even though I hate the price lol. thank you so much for all your help. you have been very helpful.
  #74
Old December 31st, 2016, 02:09 PM
kprice kprice is offline
I have everything working in HS3pro and ha-bridge with a couple of Echo Dots. My zwave test light works fine using the Test buttons. Excellent instructions provided here, by the way.
My problem is that the Alexa app cannot discover any devices. I do not have a MyHS account - which I thought wasn't needed. Only one network / subnet running as my wireless is through access points. Firewall is turned off on my Win7 Homeseer server. I do have a pfSense main firewall here, wondering if some ports need access for the Alexa app?
Both Dots are getting correct IP addresses on my network, though I can't ping them. I have rebooted HS completely and verified that the bridge starts automatically. I have also tried the Alexa app from both a workstation and a wireless tablet.
Ideas?
Kevin
  #75
Old December 31st, 2016, 02:13 PM
Ideas?
Kevin
You don't need myHS for this to work. You do need to make sure the discovery ports are open as the echos will try and search the local network for this bridge on its discovery port.
if the bridge is running and echos cant find it I would assume its a network or firewall issue.
  #76
Old January 1st, 2017, 01:28 PM
Got it working. Since my internal lan has no restrictions on ports or protocols internally, kept looking elsewhere.
Just by chance, I copied the device to a new one, edited the name and added it as a new bridge device, re-scanned in Alexa and it showed up. Same exact settings as the original device - just changed the name.
All is good.
Kevin
  #77
Old January 1st, 2017, 11:43 PM
so everything has been working great for the last two days in terms of using the home control buttons on my remote. So today my house lost power for a minute. Now I can no longer control lights from buttons on harmony remote. When I go to bridge web address and test my devices all works fine. Its just on my remote it says no connection to lights. I tried to repair hue bridge with harmony app but that didn't work. I even double clicked the RAR file on my windows controller(does this RAR file automatically run when computer is booted up or do I need to do something to have this happen???)
Do I need to do anything with my router. I checked and the harmony hub IP address is still the same as it was before power went out.
Im not sure what else to do
thanks
Chris
  #78
Old January 1st, 2017, 11:55 PM
thanks
Chris
You should not be running a RAR file as that is just a zipped file. You should be runing a Java File or .Jar file. And just like any other program it will not run automatically on startup unless you do something to set that up. The first time you probley double clicked it and ran it, but would can do again right now and be back to normal. But you should set it up to auto run on windows boot.
I actually made a folder called HA-Bridge and put it in the c:/. I put the Ha-Bridge.jar file in there and I use startup delayer myself to run all the programs I normally run during startup. PLEX, Blueiris, HomeSeer, This Bridge, and a few others.
  #79
Old January 2nd, 2017, 12:12 AM
sorry meant JAR not RAR
Do I did double click JAR file and still does not work. My devices on harmony remote say not ready however when I got to bridge address and test devices they work fine. I have tried repairing bridge from harmony app and refreshing bridge.
not sure what is going on
  #80
Old January 2nd, 2017, 12:16 AM
Not sure either but if you can get the HS-Bridge Web UI then it is running. If all your devices are still in there and everything then it knows where the config file is and it is running you previous state.
I personally don't have any problem during power loss or server reboot. It should all just work again.
Work on getting it working first then work on setting it to auto start on windows startup.
How to add devices in homekit bridge? Carlyle Harper Homekit bridge (3P) 1 November 2nd, 2016 07:49 PM
HS3 Serial RS232 Direct Control xxrzdxx HomeSeer General Discussion Area 19 August 14th, 2015 01:09 AM
URL for direct device control jgreeno HS2 / HSPRO 1 February 4th, 2014 09:23 PM
Direct HTTP (Remote Control) DrDoo HSTouch™ 1 September 23rd, 2011 05:45 PM
