Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HomeSeer Amazon Echo Connected Home API
HomeSeer Amazon Echo Connected Home API Discussions related to the Amazon Echo native support for connected home products
  #81
Old January 2nd, 2017, 12:40 AM
csullivan2005 csullivan2005 is offline
so now Im trying this:
I deleted my hue bridge from harmony app. then went to go add hue bridge again. It instantly went to the pairing part where it says press the center button in the bridge however does not get past this point
this wasn't a problem a few days ok
  #82
Old January 2nd, 2017, 10:23 PM
Im getting the following warning message below:
Still can't get my harmony remote to get past the philips hue pairing process. just gets stuck there
Anything to do with below warning message or any steps I should follow. like I said it was working great before yesterday but then remote was reporting not connected
01-01-2017 23:48:32.462 INFO HA Bridge (v3.5.1) starting.... com.bwssystems.HABridge.HABridge
01-01-2017 23:48:32.493 INFO reading from config file: data/habridge.config com.bwssystems.HABridge.BridgeSettings
01-01-2017 23:48:32.696 WARN The upnp config address, 192.168.0.3, does not match any known IP's on this host. com.bwssystems.HABridge.BridgeSettings
01-01-2017 23:48:32.696 INFO HA Bridge initializing.... com.bwssystems.HABridge.HABridge
  #83
Old January 2nd, 2017, 10:28 PM
just to be clear its getting stuck where it says philips hue bridge has been detected. press the center button in the bridge to pair it with harmony
  #84
Old January 3rd, 2017, 07:41 AM
kprice kprice is offline
"..192.168.0.3, does not match any known IP's on this host. com."
Is it possible that your IP address changed ? If you're using dhcp, you might have received a different IP after the power outage...
Kevin
  #85
Old January 3rd, 2017, 11:04 AM
this is very possible since Im using DHCP
I guess my confusion is how to setup the HAbridge
Under the section bridge control my UPNP IP address is set to what it was at the very start of me setting up this bridge
So if my local ip did change what do I need to do next in bridge interface or in my router to fix this and so it doesn't happen again. I know how to find out what my local ip is.
Sorry if this is basic stuff Im still learning as I go
Chris
  #86
Old January 3rd, 2017, 12:45 PM
In Windows, you can get to a cmd window and type 'ipconfig' and it'll show you your ip address of your computer.
You may want to set a static IP - if this turns out to be your issue...
  #87
Old January 3rd, 2017, 11:26 PM
thanks got it working again
  #88
Old January 4th, 2017, 04:22 PM
Originally Posted by Simonk View Post
Thanks for that, works great.
Is it possible with this to pass information back from HomeSeer to be read by Alexa?
I never saw an answer for this. Would what it take to get Alexa to read the status of a device? For example : "Whats the temperature in my office" ?
I have a bridge device set up that gets the current temp from my zwave thermostat from json string.
Didn't know if it was possible to send / return a response to Alexa to say.
Kevin
  #89
Old January 4th, 2017, 04:47 PM
Simonk Simonk is offline
Kevin
I've been using Jon00 Homeseer/Echo Skill Helper to get information out of HomeSeer. You can easily set up a Trigger that will do exactly what you want, see image below.
https://forums.homeseer.com/showthread.php?t=184504
I'm also working on a script that will take the text from alexa(using a single trigger in Jon00 Helper) and try to find the device that your after the status off without having to create a trigger for each device you want. As I cannot see that this can currently be done.
  #90
Old January 5th, 2017, 09:42 AM
I saw that plugin when first started, but it looked like it was just for setting up a skill that required the homeseer Alexa skill to installed.
I will take another look at it.
Kevin
  #91
Old January 5th, 2017, 12:33 PM
integlikewhoa integlikewhoa is offline
I think your right.
  #92
Old January 12th, 2017, 07:43 PM
Question Terminating the HA-Bridge
How can I terminate the HA-Bridge automatically in the VB ShutDown script when HomeSeer is shut down.
It's easy enough to start it
hs.Launch("C:\Program Files (x86)\HomeSeer HS3\ha-bridge\HA-Bridge.bat", "", "", "0")
I've tried various diffferent bits of code to close but nothing seems to close it
I can get 'cmd.exe' to close under Processes in Task Manager but the HA-Bridge remains running with a entry under Applications 'c:\Windows\system32\cmd.exe' which I cannot seem to be able to close with scripting.
Any advice on how to do this?
Simon
  #93
Old January 17th, 2017, 02:24 AM
tpchristian's Avatar
tpchristian tpchristian is offline
Has anyone encountered a problem where the harmony app will only read a handful of devices from the ha-bridge. I have 44 devices configured, but only a few load into the Harmony app. All work fine with Google Home.
It's not a huge deal, but I thought I'd make use of those buttons on the remote since I thought this should work.
- Tom
HSPro/Insteon
  #94
Old January 17th, 2017, 02:27 AM
Chris
Chris, what you want to do is to go into your router setup page and link your mac address to a static IP address so that it doesn't change all the time. Normally this will be in the section where you configure DHCP.
  #95
Old January 17th, 2017, 10:35 PM
Folks,
I have a quick and dirty script that I created to update the status in ha-bridge to keep it in sync with HomeSeer. I could share this if someone needs something like this. Like I implied it is a bit of a quick hack right now. I am using it for ha-bridge and control with Google Home. However, I am thinking that I would switch over to the direct HomeSeer interface when that is ready. If that comes out and there is some reason I would stay with ha-bridge instead, I'd probably clean this up a bit.
Is there anyone that has need of something like this now?
  #96
Old February 27th, 2017, 08:21 AM
Duomi8 Duomi8 is offline
Originally Posted by tpchristian View Post
Folks,
Hi tpchristian,
If your script updates the HA bridge with devices setup in homeseer I would be interested to see it, although personally not ready to totally automate that at this stage I can see why it might be useful.
  #97
Old July 26th, 2017, 11:36 AM
reggs11's Avatar
reggs11 reggs11 is offline
HA-Bridge has stopped working
Anyone have any ideas over why this has suddenly stopped working on my Win10 box?
I've been using it for months alongside Jon00's helper and its been rock solid.
I noticed that my Echo's stopped responding to instructions a few days ago after I disabled uPNP on my router but I don't see why that would cause issues. Even after re-enabling uPNP and rebooting everything, Test an ON or Test OFF do not work via the bridge webpage or Echo.
I get this error in the DOS box...
<..SNIP..>
2017-07-26 16:27:47,561 [main] INFO com.bwssystems.HABridge.hue.HueMulator - Hue emulator service started....
2017-07-26 16:27:47,566 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - UPNP Discovery Listener starting....
2017-07-26 16:27:47,589 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - UPNP Discovery Listener running and ready....
2017-07-26 16:27:55,305 [qtp768667677-16] WARN com.bwssystems.HABridge.hue.HueMulator - Error on calling url to change device state: http://192.168.0.58:81/JSON?request=...=239&value=255
Of course all JSON commands typed directly in to the browser function normally and all my devices are discovered normally.
I am at a complete loss and any help would be appreciated
  #98
Old July 26th, 2017, 08:19 PM
I use it, but now with Echo. Mine is still working. My first guess would be that your reference number is not correct. If you try that URL on your HS box, does it work?
<..SNIP..>
  #99
Old July 26th, 2017, 11:59 PM
reggs11's Avatar
Like l said, all JSON commands typed in to the browser work fine.
Just doesn't make any sense.
  #100
Old July 27th, 2017, 12:05 AM
Do you have a backup?
I use BLbackup to make a zip copy of the folder i have the ha bridge in every night. I have had a croupt file after unsafe shutdown before. Just delete and unzip the backup and off i go again.
How to add devices in homekit bridge? Carlyle Harper Homekit bridge (3P) 1 November 2nd, 2016 07:49 PM
HS3 Serial RS232 Direct Control xxrzdxx HomeSeer General Discussion Area 19 August 14th, 2015 01:09 AM
URL for direct device control jgreeno HS2 / HSPRO 1 February 4th, 2014 09:23 PM
Direct HTTP (Remote Control) DrDoo HSTouch™ 1 September 23rd, 2011 05:45 PM
