Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HomeSeer Amazon Echo Connected Home API
HomeSeer Amazon Echo Connected Home API Discussions related to the Amazon Echo native support for connected home products
  #101
Old July 27th, 2017, 02:21 AM
tpchristian's Avatar
tpchristian tpchristian is offline
Sorry I am not sure what you mean by on the DOS box. When you are trying it in the browser are you doing it from the same machine that you are running ha-bridge? I guess what is running through my mind is if you have any kind of firewall setup or recently enabled that would be blocking port 81 on your HS box.?
As far as upnp, I seem to recall that this may be something needed for Hue emulation. If ha-bridge seems to get the command, I guess this is not the problem anyway.
Originally Posted by reggs11 View Post
Like l said, all JSON commands typed in to the browser work fine.
Just doesn't make any sense.
- Tom
http://www.sage-software.com
HSPro, Insteon, HomeVision
  #102
Old July 27th, 2017, 02:49 AM
reggs11's Avatar
reggs11 reggs11 is offline
Originally Posted by integlikewhoa View Post
Do you have a backup?
I use BLbackup to make a zip copy of the folder i have the ha bridge in every night. I have had a croupt file after unsafe shutdown before. Just delete and unzip the backup and off i go again.
Yep, I use BLbackup as well and restored. I also re-downloaded the original jar and still get the same error.
On the hub page itself I get this error in a red popup for any device I try to test.
Request Error, Pleae look in your habridge log: error {"type":6,"address":"/lights/15","description":"Error on calling url to change device state","parameter":"/lights/15state"}
I have 30 or so devices and events and all of them used to work great.
Firewall on or off, everything rebooted. I've even tried some later versions of the jar. Nothing
  #103
Old July 27th, 2017, 03:31 AM
reggs11's Avatar
The jar file runs the HABridge server on port 85 inside a DOS box \ CMD window.
Yes same machine.
I was getting repeated access attempts on my HS3 box from outside the firewall (WAN side) so disabled the HS3 server and disabled my HS3 port forwarding on my router. You would definitely think that this caused the problem but when I re-enable everything I still get the same issue so I don't think its actually that.
I can't be certain but this appeared to stop working before I made these changes, but like I said when everything is re-enabled with all firewalls and antivirus software off, even a local Test ON from the HA Bridge gives me this error, even though local JSON commands work fine.
Yep thats what I figured as well.
  #104
Old July 27th, 2017, 07:54 AM
jon00's Avatar
jon00 jon00 is online now
Have you tried to delete all the devices in Alexa and rescanned?
Jon
  #105
Old July 27th, 2017, 08:15 AM
reggs11's Avatar
Hi Jon, nope. I've only re-Discovered\re-scanned. I'll try that later.
Whats odd is that not actually using the Echo, but just using the TEST-ON or TEST-OFF directly from the Bridge web page has stopped working so I don't think that its anything to do with the Echo. I've even removed the anti-virus stuff but no joy. Your Echo Helper is still working fine BTW of course
  #106
Old July 28th, 2017, 07:44 AM
reggs11's Avatar
Tried it, all 60 odd devices discovered again but same error.
This one truly has me flummoxed
  #107
Old July 29th, 2017, 04:44 AM
reggs11's Avatar
Found the problem. You get this error if you uncheck Setup->Tools->Network(TAB)
No Password Required for Local/Same Network Login (Web Browser/HSTouch)
When checked it works fine
  #108
Old July 29th, 2017, 09:49 AM
integlikewhoa integlikewhoa is offline
That's weird that testing your commands in a browser worked without a user and password with that unchecked.
  #109
Old July 29th, 2017, 11:45 AM
reggs11's Avatar
I use Remote Desktop to connect to my Win10 box which is headless. You cannot connect from other machines on my LAN via browsers as I've purposely disabled the HS3 web server.
In my router logs, I kept seeing some chancer trying to accesses my HS3 box from the WLAN so killed port forwarding and UPNP just to be safe.
They had the IP address and web server port so this scared the cxxp out of me.
Anyway, when I uncheck that box it immediately stops working.
How to add devices in homekit bridge? Carlyle Harper Homekit bridge (3P) 1 November 2nd, 2016 07:49 PM
HS3 Serial RS232 Direct Control xxrzdxx HomeSeer General Discussion Area 19 August 14th, 2015 01:09 AM
URL for direct device control jgreeno HS2 / HSPRO 1 February 4th, 2014 09:23 PM
Direct HTTP (Remote Control) DrDoo HSTouch™ 1 September 23rd, 2011 05:45 PM
