Need tool for linux
    Need tool for linux
    I need a Tool to modify the linux area when in windows. Like deleting file and copying files from Linux to windows etc. Any help will be appreciated. I have a plugin that bis not working and I need to sent some files to the developer and I just cannot do it . I have have been trying for a week now.
    Google and download WinSCP.
    Cheers
    Al
      Thanks Al this looks like this would work great.
      But I'm having a problem login in it keeps giving me a denied error.
      The first login screen when you start the app I used :
      File Protocol - SFTP
      Host- i used the HS3 IP
      Port - 22
      username - i used the admin login name
      password - I used the password for the admin user
      I even created a new user and I still get a denied error. Any help will be appreciatecd.
        Are you logging onto a Zee? I don't have one, so not 100% sure on the exact connection parameters and user id/password. Other posts indicate the user name to use is homeseer and the password is hsthsths3. I think the connection parameters that you are using are correct.
        Cheers
        Al
          The manual says it is looking for a Host Name in there example they used example.com.
          I know the IP of the Zee but I do not see were you can associate an IP to a name.
            The ip for the host name is fine
            Sent from my Phone using Tapatalk
              Finally got a connection to the ZEE. Had to use user- homeseer password - the system Password and it connected. I can see the files and directories but it will not let me into the root directories. it say the server will not give me access error 3. Does anyone know how to access these files with WINSCP once you are connected to your HS3 device. I think i need a Superuser assignment some how.
                Best to utilize WinSCP with root access.
                Change the password to root then configure ssh to work with root.
