Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HomeSeer Amazon Echo Connected Home API
HomeSeer Amazon Echo Connected Home API Discussions related to the Amazon Echo native support for connected home products
Old April 3rd, 2017, 12:56 AM
petez69's Avatar
petez69 petez69 is offline
Starting out with Alexa
Folks
I've just purchased an ECHO and DOT. I've read the forums and find the lot confusing, maybe if I stared at it longer it would make sense...
I gather this is the way I should install the connectivity ?
https://forums.homeseer.com/showthread.php?t=180033
I note in some forum posts, the only commands I can use are on/off , dim lights and set thermostat levels ?
Any pointers would be appreciated...
Thankyou..Pete
Old April 3rd, 2017, 02:33 AM
jon00's Avatar
jon00 jon00 is online now
Assuming you are using Amazon US Accounts, you actually have a choice of 2 skills.
Details of function and installation for each can be found here
If you want more flexibility, you can use my Alexa helper when using the Homeseer Home Automation Skill.
Jon
Old April 3rd, 2017, 06:40 AM
petez69's Avatar
Jon00
Thanks mate, had a quick look at your stuff, I like. I'll be getting it in a few weeks, look forward to having a bash :-)
AS always, good work :-)
Pete
Autelis works with Amazon Alexa? Autelis Vs Pentair Screen Logic alexa skill... bankingdom Autelis Pool Control (3P) 11 June 4th, 2017 12:03 PM
Alexa confused whether HS skill enabled so can't "Alexa, tell homeseer to..." lowenna HomeSeer Amazon Echo Skill 6 February 3rd, 2017 09:07 AM
Alexa Skill Missing for UK Alexa NicolaiL HomeSeer Amazon Echo Skill 2 October 1st, 2016 06:39 AM
alexa Gallina HomeSeer Amazon Echo Connected Home API 1 March 23rd, 2016 09:42 PM
Amazon Alexa app for HS3 Steve Q HS3 Plug-In Development 16 December 30th, 2015 11:15 AM
