My Sprinkler control in mcsControlSystems is stuck on valve 1 (device code E1). It does not advance to the remaining valves in Area 1 nor over to Area 4 (Note: I programmed 4 valves into Area 2, but when I logged back into HS, they showed up in Area 4 0 in the middle of the list; This happened twice - after deleting the plug-in and adding it back in & reprogramming it.)
The control strategy is - measured, off of virtual device code ]22 (populated with moisture reading from VantagePro) with a min level of 6. The soil moisture reading started at 11 this afternoon. The control was enabled, saw the moisture reading drop down to 2 in 30 minutes, and during that time and beyond, E1 in Area 1 kept repeating the 10 min time I had set.
My home control system is fresh - just re-created (re-formatted the hard drive & loaded the op sys, upgrades & software programs). Had the same problem three or four times before the reformat & it's occuring consistently aftward too. A log file is attached for reference.
1- Would you know why this is occuring?
2- How do I fix this?
Thank you.
Thank you.
