I have a Zipato Mini Keypad RFID (http://wiki.zipato.com/wiki/Mini_Keypad_RFID/Z-Wave
I received one of these as a gift and I'm having the exact same problem.
My log says:
Jan-26 16:40:58 Z-Wave Error Node 28 sent a NOTIFICATION resulting in a DOOR LOCK action to Lock or Unlock a door device, but the door lock device was not found.
Jan-26 16:40:58 Z-Wave Device: Node 28 Z-Wave Access Control Notification Set to NOTIFICATION for type Access Control Notification, Event: Notification Event Exception: Index was outside the bounds of the array.
Is this something that will be supported in a future release or should it be working now and I'm doing something wrong?
I've been looking around for a z-wave RFID solution. Two things:
(1) I don't think this particular one will work well with HomeSeer unless someone does a plug-in for it (?). Just by looking at this discussion for the device in Vera:
http://forum.micasaverde.com/index.php?topic=26394.0
(2) However, I did some digging, and this one looks *very* interesting:
http://www.nokey.com/avflexstanac.html
The output is a simple relay closure. Which means you could interface it to a contact closure Z-wave sensor that has external wiring capability to sense when someone presented an authorized rfid tag/card. Something like this:
http://store.homeseer.com/store/Ever...-P1083C57.aspx
Originally posted by zener57It's possible for homseer member to define one date or at least a range for supporting this unique device for security control ?
Fred
TomKassel
I also tried the (BeNext) RFID Reader with no success.
Now I use a Reader with controller (relay switch)
http://www.ebay.de/itm/350993829943?...%3AMEBIDX%3AIT
and the Fibaro universal sensor.
This works great with HS3.
Perfect workaround !
I have one Mimolite for door opener and this module was also one input for connect to the SBOARD RFID.
But I will create one BugZilla for Benext TaGReader/Zipato MiniKeypad.
Because this device it's present in configuration file ZW_Devices.dat
Line 42:
ZC08-11080001 ,008A,0007,0100, ,EU ,0000, , ,,,,,,,,Hospitality;Security & Alarm ,BeNext Tag Reader
Thanks TomKassel
Originally posted by zener57 View PostBut I will create one BugZilla for Benext TaGReader/Zipato MiniKeypad.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
RFID
Hello
Sorry to jump onto the thread - I bought a zipabox RFID mini keypad with five extra keys.
Has this been Sussed out... How to install.
It shows in my devices, however I am not able to learn the RFID tags - you tube looks like only Zippabox control centre can do this.. Does any one know how to do this and has any one got example events - how I can take a RFID and perform an action?
Yes, that is the question, indeed...HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
No, not as I'm aware of.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
